Results 1 to 2 of 2
Thread: XT/XTR 180mm??
    Bikeaddict
    XT/XTR 180mm??
    Does anyone know of an adapter for XT/XTR to take them to fit a 180mm rotor? I have lockring XTR wheels at the moment and at 160mm they arent good enough for my needs and at 203mm on the front (Shimano make a 203mm adapter and 203mm lock-ring rotor) they are fantastic but the extra weight is too much for me. If I could get a 180mm adapter for the caliper, I would consider changing the front wheel to a 6 bolt disc hub and get a 180mm rotor - I assume the XTR caliper should work with any 180mm rotor (Hope etc) so long as you can be adapted it to fit radially???
    Bad Case of the Mondays
    Reputation: Jdub's Avatar
    Quote Originally Posted by Steve Eungblut
    Well here is my theoretical (i.e. I've never actually tried it) answer:
    1. If you have a 160mm post mount, then any post mount adaptor that takes a 160mm to a 180mm rotor SHOULD work. Same should apply for the IS mount
    2. Brake track will be the concern for using a different brand rotor. But XTR uses a narrow brack track, so most rotors will be wider and therefore SHOULD work, in theory of course.
    3. I had a 160mm XTR, and wanted to do the same thing. I ended up just selling the XTR and buying 185 Avid Juicys as it was cheaper and guaranteed to work. But I was using the XT Lever/XTR Caliper setup not dual-control which made the switch easy for me.
    I'd start scouring the forums for "XTR Adaptor" and see what comes back. I know I discussed it some on this forum, and got some recommendations about what adaptors I needed and where I could get them.
  1. 180mm crank arm question...
    By FoShizzle in forum Singlespeed
    Last Post: 03-24-2005, 09:15 AM
  2. Best way to run 180mm on XTR calipers
    By FoShizzle in forum Brake Time
    Last Post: 12-10-2004, 07:59 AM
  3. Anyone using a 180mm rotor on a Manitou Minute?
    By Homebrew in forum Shocks and Suspension
    Last Post: 05-10-2004, 07:48 AM
  4. 180mm crank swap
    By Padre in forum Singlespeed
    Last Post: 05-05-2004, 03:06 PM
  5. Replies: 2
    Last Post: 01-21-2004, 04:44 PM
