Results 1 to 5 of 5
    Don't ride a Trek anymore
    xt shifter/brake combo caliper compatibility?
    just saw a craigslist listing, and the guy had a set of XT shifter/brake levers for sale. Do these work with other brake calipers? Specifically, Hayes Mags? If they do, how hard would it be to swap the levers on hydraulic brakes?
    thanks
    Reputation: Dremer03's Avatar
    I am going to assume you confirmed they are for Hydraulic Brakes? if they are should be as simple as switching the lines over and bleeding the brakes.
    Big Foot Blue KHS XC704r
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    the shimano levers will work with shimano hydros, no others are recommended (although i read someone tried matching them with maguras since both brand use mineral oil)
    Is it difficult to bleed the brakes?
    Meh.
    Reputation: XSL_WiLL's Avatar
    Shimano uses Mineral oil. Hayes uses DOT fluid. The seals will not react well with the other fluid. No go.
