Results 1 to 6 of 6
    Reputation: Hill-Pumper's Avatar
    XT Resin pad issues
    My bike came with Shimano XT M785 brakes with resin pads. After 4 rides the front still make a ton of noise until I get them really hot, then they are good for the rest of the ride. The problem is until they hot, they don't stop well. I read the tech doc and it says the resin pads take longer to seat in. I have had Shimano XT M785's on another bike with the metal pads, they burnished quickly and never had a problem. At this point about to try a set of metal pads in the front, but I was wondering if I was missing anything. I have taken the pads out, sanded both the rotors and pads, but I always get the same issues.
    After every sanding you have to seat them in again.
    I understand about them needing seating again. What is strange is that they seem seated after they get warmed up, then when I take the bike out for the next ride, it's like they are back to square one.
    Just a quick update, I switched out the resin pads with the metal pads. I seated them and have had no issues since. My LBS thinks that maybe I had a defective set of pads since the rear set seated, but the fronts didn't. It sounds logical to me, but whatever the cause, it's fixed now.
    MTB B'dos
    Reputation: LyNx's Avatar
    Well, will have to say my experience most definitely is 180 degrees to yours, got mine with finned resin pads and quiet as can be and stopping power within the first ride, so much stopping power. Also just had to switch to a spare set of metallic pads after wearing down the front resin in about 8-9 months and have had no issues with them either, only took a few short DHs for them to seat to the rotors on this bike.
    Reputation: YeahWhatever's Avatar
    Re: XT Resin pad issues
    Check to make sure your pistons are not leaking. I had a leaking piston issue with my XT calipers that caused a similar problem. I noticed more noise , and horrible braking performance. Removing the pads revealed some oily residue on the piston interface. I decided to replace the brake set under warranty and all is well.
  1. Needle bearings vs FOX resin bushings?
    By JimEG in forum Shocks and Suspension
    Last Post: 01-25-2017, 01:28 PM
  2. Are these resin or metal pads?
    By Gabe3 in forum Brake Time
    Last Post: 07-26-2013, 12:39 PM
  3. Metallic pads on shimano resin-only rotors?
    By One Pivot in forum Brake Time
    Last Post: 03-27-2013, 11:45 PM
  4. Sixpoint's RESIN explained (video)
    By JFryauff in forum Beer Forum
    Last Post: 03-06-2012, 11:10 AM
  5. Resin or Metallic Pads for my XTR 988 brakes?
    By trojans1993 in forum Brake Time
    Last Post: 11-28-2011, 05:31 PM
