    Checkin' it out
    XT rear brake help ...
    Trying to setup an XT rear brake, 160mm rotor, post mount on frame. Which adapter would work for this config? Getting a little confuse, just want to make sure and not get the incorrect one.
    It is my understanding, that without adapters, the rear post is setup for a 140mm rotor and the front is 160mm correct?
    Reputation: Vespasianus's Avatar
    No, I think it is set-up as 160 post mount without adapter.
    On MTBR, the reputation is infamous.
    Checkin' it out
    180 post/post adapter for the rear to run a 160 rotor. Without an adapter, there is no clearance to run a 160 rotor.
    Quote Originally Posted by 1996Marin View Post
    What bike is this? I am running 160 XT rears on a Turner 5-spot without an adapter.
  1. No rear brake
    By Keith Medlock in forum Weight Weenies
    Last Post: 05-18-2015, 06:26 PM
  2. Front brake vs rear brake
    By Ladmo in forum Brake Time
    Last Post: 01-25-2013, 07:51 AM
  3. Rear brake rub
    By Whitenoiz in forum Brake Time
    Last Post: 08-03-2012, 12:14 PM
  4. El Mar 3 Rear Brake
    By jmiah in forum Salsa
    Last Post: 05-25-2012, 02:51 PM
  5. Disc Brake Conversion - rear stay brake line?
    By RBatsch in forum Litespeed
    Last Post: 04-03-2011, 02:50 PM
