Results 1 to 6 of 6
    Dec 2012
    XT M785 Lever feels slow
    Hi,
    My XT M785 rear brake lever feels really slow, when i press it, it then returns slower than the front brake lever.
    I have noticed that when i push the lever outwards, the ball that the lever pushes in, is loose and goes down. this does not happen on the front brake's lever.
    What can be the problem? I have bled the brake twice.
    Thanks,
    Chrispies
    West Chester, PA
    I was having the same issue for months and it was driving me crazy. Turns out it was a very simple fix. My SRAM shifter had moved a little at some point and the shifter body was pressed against the bottom of the lever pivot pin. Adjusted the shifter so there was a tiny gap again and the lever snaps back like it should. Duh!!!
    May 2005
    Quote Originally Posted by 92gli View Post
    Thank you !! Same problem Xt785+xo shifter.
    Nov 2014
    Just built up a new bike with xx1 shifter and xt brakes and had same problem. I can't figure out how by looking, but spacing the shifter a tad fixed problem, glad I found this thread.
    Sent from my SM-T320 using Tapatalk
    Magically Delicious
    Reputation: Cleared2land's Avatar
    These are the type of easy fixes that I Like!
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    Humm... My right lever is a millisecond slower than my left lever, never think much about it, as it is really too much of a little difference, now I'm gonna have to take a look at my shifter body ...
  1. XT M785 Lever Feel Problem
    By JuliusHettig in forum Brake Time
    Last Post: 10-14-2013, 11:30 PM
  2. XT brakes M785 - lever travel, how much is too much?
    By BustedBearing in forum Brake Time
    Last Post: 09-03-2013, 12:15 PM
  3. Replies: 6
    Last Post: 07-18-2012, 10:25 PM
  4. xt m785 lever pull
    By vqdriver in forum Brake Time
    Last Post: 06-04-2012, 08:33 PM
  5. XT slow lever return
    By skywalker268 in forum Brake Time
    Last Post: 02-26-2012, 01:54 PM
