Results 1 to 43 of 43
Thread: xt m775 issues
    Jan 2009
    xt m775 issues
    Hi! I just installed a new set of m775 xt brakes on my rig and have had nothing but headaches with them and was hoping for some insight. I seem to be having two separate issues with my rear setup.
    Issue 1: upon braking there is very little power (to be expected as they are brand new) but as apply more pressure the brakes start to grind and squeal culminating on a very deep vibration as the brakes finally grab. I've already bled the brakes (had to switch the lines as they came pre-assembled backwards), I've checked all of the rotor bolts, and re-aligned the caliper a million times. Any ideas what else to try/redo/look into?
    Issue two: on the lever it seems that the actuation piston is somewhat sloppy compared to the other lever. The brass bushing on the bottom in the guide channel is able to click to the very end of the channel (god I hope that makes sense). Is this a legit situation or something menacing? To answer the obvious question... No, the brakes haven't been crashed on.
    Thanks the insight.
    DGB
    DGB is offline
    Another couple of things to check for issue #1 (and you may have done this already, so don't take offence).
    From reading your previous posts, I see you are not a newb so I'll presume you know how to bed-in pads.
    What I've found is that anytime I get squealing from my M775s is when I've got some sort of contaminant on either the pads and/or the rotors.
    You may have inadvertently gotten some mineral oil on either the pads and/or the rotors when you were swapping over the brake lines or bleeding. I'd clean the rotors thoroughly with some alcohol and flame the pads over a gas burner until they get good and hot to burn off any contaminants, which you will see as smoke.
    Repeat the bed-in process and you should be good to go.
    Failing that, check that the rotors are installed with the correct rotation.
    As for issue #2, I know what you mean. (I'm currently looking at a broken MC in my hand). If you push the lever away from the bar this brass bushing also moves further to the front of the "channel". This is normal and happens in all of the M775 levers I've seen.
    This brass bushing is adjusted by means of the free-stroke adjustment screw. If you turn the free-stroke adjustment screw out (anti-clockwise), the brass bushing moves further to the front of the "channel" that you mention and vice-versa when you go clockwise.
    I hope this helps.
    ...twanged rotor...
    Say Folks, does anyone have a trick way to straighten slightly bent disc brake rotor? I have my way of doing this (rubber mallet/visible correction after marking) but it is time consuming. I do this process right on the bike using the caliper as a "truing stand". any better idea"s...big and tall
    Jan 2009
    DGB,
    Thanks for the ideas, I did bed the brakes in properly so that is at least one thing off the check list. I verified rotor orientation this morning all is well there. Also, while bleeding I removed the pads and installed the supplied bleeding spacer. I am quite certain I did not get any mineral oil on the pads during these processes. BUT, this does not mean that during the shipping/factory assembly and bleeding process something didn't get splashed on the pads. I will go ahead and torch them tonight when I get home from the office and see if that helps correct the situation.
    (issue #2) good to hear its somewhat normal, I was just concerned as one lever did it and the other did not... maybe its just a matter of time before the other one joins the club.
    Jan 2009
    Quote Originally Posted by big and tall
    Truing rotors are better done with a truing fork OR a crescent wrench dialed into the thickness of the brake rotor. find the area that's out of true and bend accordingly. I would steer away from using the rubber mallet method as there is no guarantee of accuracy and you may be able to damage the rotor.
    ...truing rotors 2.0...
    Thanks for the input markjk4, the cresent wrench method does seem to be a better Idea. I"m going to true the rotor up on my Hanebrink Extreme Terrain that way asap. Should quiet my Avid Juicy 3.5 "s down nicely...big and tall
    Quote Originally Posted by markj2k4
    DGB,
    Try greasing the rotor where in contacts the hub, or splines if it is centerlock.
    Jan 2009
    Quote Originally Posted by jeffscott
    Im going to degrease the whole rear end (rotor, contact points, caliper etc.) and torch the pads, I would love it if it was just contaminated parts.
    DGB
    DGB is offline
    You might have got some oil on the rotors, maybe. So give them a quick clean, just to be sure.
    Adjusting the free-stroke screw should sort even out the lever differences.
    Thats fine but three things
    Apply grease on the contact points to help damp vibrations...
    And I find heating the pads in a fry pan on medium heat works better than a torch.
    If you are going that far you should very lightly sand the pads after heating,
    sand the rotor once the wheel is back on the bike, to break and glaze.
    Just spin the wheel, with a piece of sand paper between your fingers squeezing the rotor.
    Jan 2009
    yea... absolutely no dice with any attempt at stifling the resonance. Here's what has taken place:
    torching pads
    sanding and cleaning rotors
    lightly greasing the hub contact point on rotor
    adjustment of caliper alignment (several times)
    greasing of the dropouts
    tightening of the dropouts
    alignment of the dropouts
    nothing.
    I am wondering if it will eventually just fade away and I am just experiencing the brakes hitting a perfect frequency to resonate the frame. I can feel the vibrations substantially in the seat and handle bars.
    for reference frame is a voodoo d-jab (titanium with sliding dropouts) setup as a single speed with king hubs.
    Reputation: wormvine's Avatar
    torching pads
    nothing.
    I had the same issue with brand new XT M775's as well. Tried everything you did.
    I sold them on ebay...
    Jan 2009
    Yea, I am hoping to get it sorted, the brakes are pretty nice otherwise. If wearing them in does not work, I will try new pads (oe or non-oe) and see if that helps. If not I may have to pass them on as well and try something else.
    crap, did you order these from ribble? I just ordered some from there, I hope they dont have the same issue.
    I <3 the m775 brakes that came with my anthem......
    Jan 2009
    Ordered from merlincycles... I am sure you should be just fine. I doubt its anything really major anyways, there's so many other factors that can cause problems besides the obvious problems with the brakes... e.g., loose hub, unfaced frame, contaminated parts etc. If it's any consolation (for me) braking power has exponentially increased but most of the irritatingly loud vibration is still present. It's more embarrassing than problematic anyways...
    Vaginatarian
    are you using the resin or sintered pads?
    Ive had alot of issues with the sintered
    also make sure the pistons are comming out evenly, if not you need to re center the pistons
    Jan 2009
    Quote Originally Posted by dan0
    They came equipped with sintered pads... I may switch to organic pads, still up in the air. I do ride the entire rain season here (San Francisco) and prefer sintered's abilities to withstand wet riding, but much rather have the peace and quiet of organic if it came down to it.
    Off the back...
    Reputation: pinkrobe's Avatar
    I found that the sintered pads that came with the m775 were unbelievably loud and jittery, but stopped okay. I switched to Fibrax metallic pads and they stop just as well, but without the noise and vibration. I haven't used organic pads for a while, so I can't say much about them.
    @pinkrobeyyc
    #pinkrobeyyc
    DGB
    DGB is offline
    If you're riding in the wet, IMO, you're better off to stick with the metal pads. The resin ones don't last at all in wet n' gritty conditions and I've found that their braking performance is not up to the level of the metal pads in those conditions.
    I'm wondering is there an issue with the sliding dropouts on your frame causing the resonance - ensure they're tightened to the correct torque and I'd use some threadlock to prevent them from loosening. This might help with the noise.
    Is the noise as bad from the front brake as the rear?
    Jan 2009
    Quote Originally Posted by DGB
    Yea, I totally know about the wet stuff and resin pads.
    in referencing the front brake it's like night and day. While it isn't silent, it is as quiet as it should be, hardly making more than a slight squeeky chant under hard braking. The rear sounds like a tuba in comparison. I think I might pull the rear end apart again, clean the drop out channels then apply a liberal amount of fiber-grip to both dropout and re-install. Metal on metal contact can sometimes do naughty things.
    Vaginatarian
    try swapping the pads from front to rear, that will eliminate one possibility
    Im now to the point of trying a different rotor, Ive done everything else
    Jan 2009
    Well sir, there was a factor that I never really considered... two entirely different pads (fronts were organic and quiet and the rears were sintered). now I have a some what squeeky front end (not nearly as bad as the resonance I got from the rear) and a silent rear. I do have a larger rotor on the front so I will rebed in the front brakes and roll it with the sintered for a few rides and see if it quiets down. If not I would be willing to take suggestions as to quieter metallic/semi-metallic pads for the winter. I do prefer low noise as sometimes adventures take me into areas where I rather not stir up wildlife or areas where boundaries are questionable.
    Vaginatarian
    I hear ya
    I also tried goodridge sintered, loud as well. maybe a different brand of rotor might work?
    I have an avid rotor on my other bike, Ill swap it and see, more tomorrow
    Hates rain
    Reputation: mike11204's Avatar
    Shimano Sintered pads made a hell of a racket, Clark's organics solved all of my noise issues, though I used the noise as an excuse for some Alligator Serration rotors and love them.
    ...brake pads...
    I"ve had good results using the pads that came with my Avid Juicy 3.5"s. Does anyone know what the part number is for these units? I"ve never had to take them out of the calipers (new bike) and i want to order a spare set for future use...big and tall
    Hi.
    Reputation: jtmartino's Avatar
    I've used car brake pad lube on my bike before - helps to silent the vibration transmitted by the pad. Put it in-between the back of the pad and the caliper.
    Jan 2009
    Quote Originally Posted by jtmartino
    Tried it, no dice. I went ahead and picked up a set of kool-stop organic pads this morning to throw in there for the time being, decently cheap to give a shot (14$). I'll see how these work out, and report back.
    Jan 2009
    new pads in, bedded and seemingly good to go, they are also silent (naturally). I'll thrash on them tomorrow on the trails and see if I can get them to cry and see what these kool-stop pads are all about - I use kool-stop exclusively for rim brakes.
    Seems every brake has some issues depending on the frame and brake combo.
    Hates rain
    I noticed most of my problem was actually from the wheels. The formula hubs that came stock on my bike were fine with the sintered pads but when I swapped the wheelset out for Mavic Cossmax's I got severe resonance on the front end but, the organics cured the noise.
    Jan 2009
    Quote Originally Posted by mike11204
    I am using king hubs, I suspected a loose axle at first, but that all checked out. But I could see how the hub would play a role in the chaos.
    I do have the bike strapped to the roof for a post work constitutional, it seems as if it was solely a pad problem but I am not going to be sure until I really give the pads a work out. This will also afford me the opportunity to torture test these Kool-stop pads and see if they are any good.
    Jan 2009
    seems like smooth sailing for now, atleast until the wet season.
    FWIW these kool-stop pads are alright, but they do squeal like a b*tch when they get hot. I wonder what the actual pad composition is... Kool-stop doesn't disclose any info on their pads.
    No longer a hardtailkid.
    Reputation: hardtailkid's Avatar
    I have the same problem with my SLX brakes. I am using a Hayes V6 rotor out back, and a V7 up front. The resonance is extremely annoying. I can't stand it. Being on a teenagers budget, I can't really do alot of experimenting with rotors, pads, etc... What seems to work for me (for about 1 ride ) is putting a piece of an old innertube between the caliper and adapter and also two more pieces between the adapter and the frame. I need to find a better product/material to use, but it seems like a good idea.
    What kind of rotors are you using?
    -Andy
    Quote Originally Posted by anthonys
    Its still just the push of a button away...
    I am no longer a hardtailkid. 2012 Trek Remedy 9!
    Never trust a fart
    Reputation: frdfandc's Avatar
    hardtail,
    Save your pennies up and get the Shimano rotors. They are avail in both centerlock and 6 bolt.
    Have you used them personally with SLX or XT brakes? I really want to get new rotors and I have almost $500 saved up, but I am saving for a Jamis Parker II from Jenson. I don't want to spend $80 on those new rotors, honestly.
    Quote Originally Posted by hardtailkid
    If your bike is 6 bolt get some Alligator round type rotors from Pricepoint.com best deal going on rotors and they work.
    Yeah, I was thinking about them. I haven't heard many people talking about them. They are alot like the Hayes V series rotors, so I don't know if they will be any quieter.
    Hates rain
    I got the Serration rotors for $14 at Pricepoint and really like them. Unlike the Hayes rotors, they dont warp after a long downhill. Ive had them for 3 weeks and they are still perfectly true. Plus they are very light.
    I have run Hayes V8 and pre-V 8 inch rotors with several sets of Shimano XT and Saint brakes (previous and current generation) on several bikes with no issues, including both of my current DH bikes. You might need a thin metal washer on each mounting bolt, between the adapter and the caliper, as my V8 rotors occasionally rub on the caliper body between the brake pads without one (Shimano rotors are a bit thinner and have rounded edges on the outer edge of the rotor, which gives more clearance in the U shaped groove in the caliper). Organic pads are also a lot quieter than metallics but wear out faster; my favorites are Shimanos or EBC reds.
    Are there any guys on here with some lightly used rotors that for whatever reason, they might want to get rid of? I don't mean to be a begger, but I just don't like spending so much $ on a part that wears and performance varies from combination to combination. It's just an expensive experiment!
    Are there ever any rotors on Chainlove.com??
    HOLY CRAP!!!!!!!!!!!!!! GUESS WHAT JUST SHOWED UP ON CHAINLOVE!!!!!!!! I SWEAR TO GOD!!!!!!!!!!! CRAAAAZZYYY!!!!
    ^spaz...
    Jan 2009
    Mike,
    what pads are you running with the serrations? I might try to roll those with some sintered pads for the winter... I would almost expect the shimano rotors I have to completely gum up with mud during the rain season, I might stand a chance of keeping the rotors clear with something more like a serration rotor.
    Hates rain
    I run the clarks organics but I will be testing out a set of alligator organics this weekend.
