    Reputation: lebikerboy's Avatar
    Jan 2005
    XT M755 front caliper on the rear?
    I have found a set of NOS XT M755 brakes however both calipers are for the front. Does anyone know of an adaptor that will allow it to be run as a rear and what size rotor will it support.
    Thanks,
    Reputation: Wombat's Avatar
    You will need a 140mm rotor (I think Hope made these). You can try a 200 mm Grimeca adapter and see if you can find a 180 mm rotor, but I think most are 185 mm. Maybe the newer 203mm Shimano adapter is close enough to run the 185s, but you might find that the pads don't clear the calipers. Go-ride has these adapters.
    I assume that the brakes come with left hand levers; what are you going to do about this, as I think Shimano levers won't operate very well if run on the wrong side?
    Wombat
    Alpine Rider (Italy)
    Reputation: 30x26's Avatar
    Quote Originally Posted by Wombat
    grimeca sells 180mm rotors. both adapter 160-->200 and rotor are cheap. this is my front caliper + adapter 160/200 + 180mm . mine is not perfect but it's usable (it doesn't seem but pad wear is good). i think it would work very well on a modern bike without the second adapter :-)
    Authority is dead!
    Reputation: Lucky13's Avatar
    try discbrakeadapters.com they have a lot of adapters.
    For the love of Oi
    Rent a house at Attitash
  1. xt front and rear derailleurs !
    By wolfeinstein in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-07-2005, 07:09 AM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. Replies: 67
    Last Post: 12-07-2004, 04:52 PM
  4. Replies: 14
    Last Post: 04-23-2004, 02:35 PM
  5. Intersting observation on 2004 xt front der....
    By ToddM in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-13-2004, 11:47 PM
