Results 1 to 5 of 5
Thread: Xt hose cutting
    Xt hose cutting
    I need to shorten my 04 xt hose, after removing it, it seems like the olive is pretty much fixed, do I just cut it off and put a new one on? Also, can this be done without a re-bleed like the Hope Mini's?
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    You need to cut the hose, put a new olive and bleed the brake. There's no other way.
    Thanks, will do!
    Seriously ?
    Reputation: Spiff's Avatar
    Quote Originally Posted by happybiker
    How did you remove the hose ? you just pull very hard until it come off ?
    Gui
    Undo the threaded nut, and then wiggle the hose while you pull on it, it comes off without too much hassle.
  1. 3rd party hydro hose for Shimano XT brakes
    By eastman in forum Brake Time
    Last Post: 03-04-2004, 09:49 AM
  2. 04 XT Integrated Brake/Shifter with
    By OffRoadRoadie in forum Brake Time
    Last Post: 02-27-2004, 12:40 AM
  3. Input on swapping XT disc to new frame
    By Loudpawlz in forum Brake Time
    Last Post: 02-26-2004, 11:03 AM
  4. Replies: 0
    Last Post: 02-19-2004, 11:24 PM
  5. Can I cut metallic XT hose?
    By MNMN in forum Brake Time
    Last Post: 02-11-2004, 03:26 PM
