Results 1 to 5 of 5
    Reputation: Thatshowiroll's Avatar
    Jan 2009
    XT Brake Block Dimensions?
    Looking for the dimensions of the blocks/inserts used for bleeding Shimano disc brakes.
    I want to make a pair.
    Lemme go measure some
    Thickness: 1cm
    Length: 3cm
    Width: 2cm
    The thickness is the key.
    Jan 2009
    Thank you so much... repped.
    No sweat man, glad I could help. I've actually sanded the thickness down on others to account for pad wear. That way lever feel is consistent.
