Results 1 to 5 of 5
    XT Brake Bleed - Made Mistake, Now Cannot Push the Pistons Back
    First brake bleed. Well, things were going well (so I thought) until I was squeezing the lever without realizing my bleed block (a 10mm allen) had fallen out. I must have knocked it out at some point without noticing.
    Now I cannot for the life of me get the pistons back into the caliper. They are spaced about 5mm apart and will not budge. I have accidentally squeezed my levers with the wheel off before, so I have reset the pistons before with no problems.
    I tried having the screw cap on the lever open while trying to push the pistons back in, to no avail. I'm sure that by now the line has quite a bit of air in it too, since I had fluid flying at one point...
    I did a quick search and couldn't find anyone as dumb as I am, or at least one willing to admit in public that they did something this dumb.
    Anyway, and thoughts/comments/suggestions would be greatly appreciated. Sarcastic comments about my incompetency are fine, too.
    Reputation: nickz5's Avatar
    May 2010
    Re: XT Brake Bleed - Made Mistake, Now Cannot Push the Pistons Back
    There is a pdf from Shimano about resetting your pistons which you can Google. Obviously make sure the brake line is open meaning top cap off etc and make sure pads are off! Make sure you push them back with something plastic like a thick tire lever.
    May 2010
    My other suggestion is to wiggle the lever side to side a little as you push it back, and may smear a little mineral oil on the side of the piston to help. Once they are back in clean only with iso alcohol, no drinking.
    Thanks! A little mineral oil, wiggling the lever and some patience did the trick.
    May 2010
    Sweet !! They are great brakes.
  1. Think I might have made a mistake in my order..?
    By shawnt2012 in forum General Discussion
    Last Post: 03-07-2013, 12:11 PM
  2. Made a mistake, now i need to fix it!
    By Garth Algar in forum Bike and Frame discussion
    Last Post: 01-09-2013, 09:13 AM
  3. New to clipless, have I already made a mistake?
    By donutrider in forum General Discussion
    Last Post: 08-07-2012, 10:01 AM
  4. I might have made a mistake.
    By 2wheelsnotfour in forum Ibis
    Last Post: 08-18-2011, 10:26 AM
  5. Not sure if I made a mistake
    By rdickens48 in forum Motobecane
    Last Post: 07-17-2011, 10:46 AM
