Results 1 to 77 of 77
    XT 4 pots, all the way!
    my bike:
    and of course my brakes:
    front:
    rear:
    levers:
    Comments:
    1. rear line switched to Goodridge too. (pictures soon)
    2. do NOT ever buy Goodridge alloy connectors! only Stainless steel! i swapped my levers fittings to SS! too small fittings to be alloy...
    3. KOOL-STOP pads. i liked them the most!
    4. SWEET BRAKES SYSTEM!!!
    5. updated pictures soon!
    Reputation: cubeman's Avatar
    Dec 2004
    Looking good!
    Nice brakes turned into someting even nicer
    Still waiting for my second set of 4-pots, possibly the best brake ever made!
    Reputation: Sim2u's Avatar
    Nov 2006
    I have them too in the 06 Reign, great breaks butI will be updating htem soon to the Hope M4 4pot breaks...MUCH better, lighter, one peice magic design, GREAT rotors as you already know. So, I will retire my XT 4pots...
    As a side note, how are they with the floating rotor...?
    Mar 2006
    it seems that your goodridge fittings isn't screwed in all the way??
    yep, as i wrote, already been fixed.. the problem was with the alloy fittings they are sucks! (brook up when trying to screw them all the way) so i switched to stainless steel fittings on the levers. much better!
    i'll post new pictures soon.
    Mar 2006
    good to hear that..
    I got some 1set of 4pots on goodridge alu fittings too.
    fitted nicely and had fitted plenty of them with other brakes too (about15-20 sets) and only 1 breakage so far.(crossing my fingers)
    only 2/5 weight of the stainless stain ones..
    i get some pictures too...
    nnn
    nnn is offline
    Reputation: nnn's Avatar
    Feb 2005
    Damn, this makes me wanna go all out for a set even more, BB7s are great but no compairson. That looks sweet !!!
    I am back!
    Reputation: markito200's Avatar
    Nice set!
    I have a set of m755 with the m756 levers. How are those dangerboy levers? I have been on the verge of getting them for some time.
    Meh.
    Reputation: XSL_WiLL's Avatar
    I love my 4pots (except for the rather high cost of adapters).
    Reputation: Prof's Avatar
    So what you are saying is
    Edit (naff post)
    Stay off the brakes
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    I have 4-pots front and rear on both my bikes, and they won't be leaving anytime soon.
    One set is from the first release- 2001? And still going strong. New hoses and fresh fluid/pads are the only upgrades on that set. Amazing how much abuse the levers take! They are still slop-free.
    I have yet to find a brake that compares, unless you spend 3-4x as much... and even then you don't have the small parts availability you get with shimano.
    I went with hope hoses and straitline levers on my AM bike, I liked the brakes so much after 5+ years it seemed right to pimp them up a little bit. I also replaced all the bolts on the levers with stainless steel hex fittings from my local hardware store. They should be good for another 10 years at this rate!
    Reputation: Znarf's Avatar
    So I finally did it.
    I ordered a brand new, unused set of 755xts with 756 levers and standard hoses (will do it for the moment). Ill get some 160mm rotors, but I wont use them. Ill directly get some 8" rotors.
    And Straitline lever blades of course.
    I am coming from a set of 2007 Magura Gustav Ms and before Ive been on Deore 525 and Saint Discs (Straitline levers on the Saints, too)
    I loved the Saints, especially the Straitline levers, then got upgradeitis and bought the Gustavs (I work at an LBS parttime, so I get nice deals) and while the braking power is nice and consistent I hate the lever feel of the Gustavs. 2finger or 4finger blades, both dont work with my hands. Alsoat 149lbs, I dont need that much power.
    So I always loved Shimano parts for their second to none finish and excellent quality control. And I always wanted a set of the 755s, just never had the cash.
    I will sell the Gustavs for sure, even if they are top notch brakes and a thing for themselves, just not for my hands
    Now it was either, a set of 2008 Codes or get some 755s and pimp them.
    Seeing quite some defective Codes or little issues with them, I went for the 755s.
    Ill get an 8" adapter for my Fox 36 PM fork and an IS to IS8" Adapter for the rear, does anyone have the numbers?
    Which rotors should I get? Just some XT8" as they are cheap or something else?
    I always felt that the 6bolt XT rotors had a bit less braking power than the newer centerlock XTs with the curvier pattern.
    Also the Hope floating discs for the M4 look killer, the M4s even use the same pads, should be a nice combination. Do you notice any better heat resistance with the floatings? Or is it just optical bling?
    Greetings Znarf
    Reputation: daisycutter's Avatar
    magura
    how much for the gustavs?
    Id sell them for a good price, but I live in Europe. I guess shipping would be too expensive?
    Its a 210/190mm f+r set. Comes both with a Post Mount and a Boxxer adaptor for the 210mm front disc. long hoses and brilliant condition. Also comes with the 2 and the 4 finger levers and a bleeding kit and the manual and some shims. Id sell them for 500$ (plus shipping), mint condition. Pads are just bedded in.
    Greetings Znarf
    ost
    ost is offline
    Oct 2007
    thought i'd add some pretty pictures to the discussion
    if you're not breaking stuff, you're not going faster
    Reputation: gticlay's Avatar
    Are those the same as Grimeca and Sram's old ones?
    Meh.
    Quote Originally Posted by gticlay
    Similar, but not quite. The XT uses mineral oil, I believe those two use DOT fluid.
    emtb.pl
    Reputation: krolik's Avatar
    755 with XTR DC
    Yep, I had such a set two years ago on my Kikapu - 755 4pot paired with the '04 XTR Dual Control lever/shifter set. Haven't seen anyone else doing it You did see 755 levers paired with XTR callipers (for those who didn't like DC) but not the opposite. Anyway, it was doable and quite nice. Two years without single issue.
    I switched to Hope M4 for the BLT though - a lot more power but I use 8"/7" rotors f/r
    Dec 2004
    Quote Originally Posted by krolik
    Here you go, January 2005.
    A guy I know combined 4-pot calipres with XTR DC
    He's a mech so he knows what he is doing.
    I was hoping someone had both the 755 and the Mono M4 to know how they compare.
    Stray Bullet
    Reputation: Nagaredama's Avatar
    Anyone have any tips on how to get 4 pots to work with either 8" PM direct front or rear mounts?
    I've got a Trek Session 10 and the rear mount is 8" PM direct. Maybe use the smallest Shimano adapter and a 220mm Formula rotor?
    Meh.
    Yeah, you'll have to use an adapter and up the rotor size. The minimum increase is 10mm... so that'll bump you to 213mm. And you can shim out the adapter with 3.5mm of spacers.
    Prez NMBA
    how difficult is it to change out the levers on the orginal handle assy and what is the process? ive bent mine a couple times and one of these times its gonna snap when I try to bend it back
    emtb.pl
    Quote Originally Posted by cubeman
    I thought I was the first and last person on the planet
    Anyway my worries were if the pistons were identical in the 755 and xtr lever units in terms of volume/stroke. I wasn't worried about fittings/cables and other stuff, bacause shimano makes them homogenic. But there was no way to check it other than by doing
    All came out ok.
    Ypu'll probably see sh!t on these photo's in terms of 4pot XT's but it;s all that's left.
    24h race in 2005
    emtb.pl
    755 vs M4
    Quote Originally Posted by Jerk_Chicken
    JC - I can try to compare the two sets but I had 755 with 6" rotors and the M4 uses 8"/7" now so you have to filter what I state.Plus they were never on the same bike. the wheels are the same though and tire setup is simmilar to what I had in the last few months of the Kikapu. And my better capabilities are equaled in the weight gain 200lbs now and used to be 180.
    OK, here we go, my shy $0.02:
    1. Modulation/Power
    I'd say the M4's have way better modulation and are ALOT better in dispatching heat. The heat dispatch is better thanks to the size of the rotors and the alloy spider - at least that's what they advertise Anyway the 755's were geting realy hot during long descents and the M4's don't.
    I wouldn't say M4's are a lot more powerful and that's with the bigger rotors taken into acount (I think they'd have about the same bite with equal rotors). I was hoping m4's would be stronger. Can't use it with one finger realy. None of them.
    2. Design/maintance
    The 755's with the XTR DC had a kind of 'flexy lever feel' (thanks to the DC)
    755's with the original levers were harder but the levers did tend to get loose and clunker in the rough stuff without any hope to fix that - M4's have a nut to tighten there.
    755's use Mineral oil and that is easier if you like to mess with your setup. M4's use DOT which on the other hand is supposed to handle heat better.
    I used the 755's for 10k miles. I never, ever had any problems with the 755's in terms of taking air. And the metalic pads lasted ages there!
    I use M4's for a year now and just under 4k miles - no issues whatsoever.
    3. Looks/bling
    judge yourselves but I say nothing looks better than Hopes. 755's made the kikapu look like a motorbike but that was in 2004
    And don't forget, which you likely know, the M4's use the same pads. In fact, I use Shimano m03 metallics in mine.
    emtb.pl
    And how do you like it compared to stock?
    I've posted elsewhere in the past along the lines of the cost factor making them a no-brainer. I do like the Hope compounds, but the Shimano is close, especially at $10 less per set. Springs are bent a bit narrower on the Shimano models, but it's still functional. I have a bunch of sets, along with some Hope golds, and some Ritchey metallics that were on Fleabay for like $15 shipped for 2 sets.
    emtb.pl
    Impossible to find anything in that price range in Poland. In fact, when you compare prices of bike stuff in US and Europe, you get exactly the same numbers but in different currency That's sad, everything here is 30-40% more expensive. That's why I buy most stuff in the US - makes sense even though I pay for shipping.
    emtb.pl
    btw are the gold hope floating rotors a special edition or are they available in multiple colors? Mine are just grey and gold might suit my ano orange BLT
    They didn't give me any choice by purchase.
    Nov 2006
    Yes they do come in different colours. Here is a link to some of them if you navigate this site and look around, they have other things too. Just as a means of looking at what they have ane not necessarily buying from this site...!?
    SITE
    Break kits
    Rotors
    Somebody state if this site is a good one to purchase from because I am unsure. I think it looks good (not aesthetically though) and they have a GREAT sellection.
    Meh.
    Quote Originally Posted by Sim2u
    SITE
    Break kits
    Rotors
    Somebody state if this site is a good one to purchase from because I am unsure. I think it looks good and they have a GREAT sellection.
    I bought some stuff from monkamoo on ebay before. I got it without any funny business.
    PS - B-R-A-K-E
    emtb.pl
    thanks guys,
    I got my floating 8"/7" as an upgrade from std one piece and received the former M6 model (not wavy). There was no option to it. I might just take a shot now with the gold ones. They seem dark enough - has anyone paired them with CK mango hubs? I'll probably have to post a separate thread on this one.
    Nov 2006
    Bit of a late reply here mate...but thanks Will.
    will try-em.
    PS - B-R-A-K-E
    Hello again!
    I am thinking of "maybe" upgrading my 4pots with some Goodridge lines.
    Is there a noticable difference in lever feel?
    I`ve got some Straitline levers and HAYES V8 rotors, so I think I could also go ALL THE WAY, too.
    Greetings Znarf
    You won't notice a difference in feel. The only way is if the system needed to be bled to begin with. I replaced the stock hosing with steels a couple times to find no difference. These brakes were well maintained with recent bleeds.
    FM
    FM is offline
    Apr 2003
    Quote Originally Posted by Znarf
    Hello again!
    Greetings Znarf
    Just get the Hope hoses (made by goodridge)- you can get them through seller monkamoo on eBay. The reason to get the hopes, "kit #0" includes fittings you may need to pair newer shimano levers with older calipers, or replace the older 90d. banjo at the levers with in-line connections.
    I have two sets of M755's, one with hope hoses and straitline levers, the others are stock. I did feel a subtle change in feel when going to the hope hoses, but there are so many variables it's hard to give the hoses credit. A good upgrade though I think, certainly more durable than the shimano hoses.
    Ok, so Ill just spend the money for some lift tickets, or save it until I rip off a hose.
    My Float conversion turned out BEAUTIFUL btw. I just dont have toooo much spare time at the moment to post some pics and make a write up.
    The Float uses the travel very good actually, pretty astonishing...
    Greetings Znarf
    Nov 2006
    Oh man...what a nob I am. I just noticed that you pointed out my typo on "break" to "Brake"...ha ha ha. Wow...I'm slow but I get there in the end...usually, well ok sometimes!
    Just smacked my M4's on the XO and boy oh boy, don't they rock. Back to back, apart from oil choice, I love my M4's to that of my XT's - as classic as they are.
    will try-em.
    Reputation: ecox's Avatar
    Yep, XT 4 pots are the way to go. I'll never give mine up. (Unless the new 4 pot Saints are really that much better.)
    Nov 2006
    Speaking of the 4pot saints, they are still a 2 piece affair though, with some weight reductions. Still be interested in how they perform though. And as much as I love my XT 4pots, I really hate the massive nipple...(also related to the m4's) This is where I like Avids version of the internal nipple, or bleed port as such.
    Speaking of lighter weight, I replaced all the bolts on my XT 4 pots with titanium. Saved a bunch of weight right there.
    The new Saint 4pots seem to have a higher leverage ratio, maybe an even "stronger" servo-wave.
    I expect them to be not too expensive, Shimano prices are really, really low over here in Europe. All those OEM-online sellers make Shimano retail prices obsolete.
    So ill just get a front brake and test it against my 755s.
    But I think they are not available until August or something.
    Greetings Znarf
    Nov 2006
    Yeah a bit later I'd imagine...I am going to get the Rr Mech though, very keen to check that out.
    TI Bolts...where did you snap up those beauties, are they appropriate...!?
    I got 'em at hyperbolts.com. You need 12 -- 4 for the front caliper, 4 for the rear, and 2 each to mount the caliper to the frame/fork. I've been using them for the past year with no problems, and 60 grams or so in weight savings.
    Nov 2006
    Sweet...thanks for the info aswell.
    60 grams is substantial in terrms of brake (BRAKE, he he he) weights as such. Consider them on my "To do and get" list.
    NICE!
    Do you have exact numbers of the needed TI-bolts? M5x10mm or something like this
    Seems like a nice upgrade, add some TI-rotor mounting bolts and youre at about 90g weight saving, without performance loss Id think!
    Greetings Znarf
    NICE!
    Greetings Znarf
    Shoot, I don't. I do know that the diameter of the 4 for each caliper are the same, but two are maybe 20mm, and 2 are 18mm. The two that mount the caliper the the frame are obviously bigger. You can figure out the head diameter by seeing what hex wrench fits, and measuring the length can be done without removing any bolts. Should be pretty easy...
    Pixie Dust Addict
    Has anyone tried the new XT servo-wave levers with the 4 pots? I have a set that I've been hanging onto for a special occasion. I am thinking of replacing the Martas on my Sultan with my 4 pot calipers and the new XT levers, if they're compatible.
    nnn
    nnn is offline
    Feb 2005
    Aparently the new servo-wave levers use too high a pressure for the 4 pot seals so it's not a good idea to use them.
    "Life begins at 140" Richard Burns
    http://www.nikolay-k.com
    COOL BUZZ & TASTY S-TRACK
    Reputation: spacoli's Avatar
    After years of reading about the performance of these brakes, I picked up a pair of these brakes on the classifieds for under $100. They still had the SS line and I changed over to the standard Shimano lines.
    I installed them on a P2 bike and was hoping to move them over to my trail bike, but I can't seem to get power out of the front with a 8" rotor.
    I have bleed them out a couple times with no success.
    I followed the simple Shimano bleeding instructions. Does anyone have any bleeding tips?
    I can fix it............... my dad has an awesome set of tools
    Nov 2006
    It may be obvious, but perhaps you should also try cleaning the pads surface with some wet'n'dry sand paper and then clean them after with some alcohole (not the drinking type, he he he) and then also clean the rotors.
    I have the same set up on my R1 with an 8" rotor up front and it has excellent stopping power with a 20mm Front Axle.
    Best just to go through them logically as you have been doing already, and I am not sure if you have done your rotors and pads yet as mentioned above, but they as you know, can effect the performance greatly.
    Meh.
    If you can't get it sorted, I'll buy them off of you.
    Nov 2006
    Ha ha ha ha...folf.
    I have cleaned the rotor and pads with alcohol, but I didn't sand the pads. I may try sanding lightly.
    XSL_WiLL, sorry bud, but I will get them to work. I know how you feel, they seem hard to find because nobody want to let them go. I was glad to find a pair at a killer price.
    Nov 2006
    use the alcohol after sanding too spacoli, it will help take off any other contaminants that the sanding brings up. After cleaning and sanding mine back to a flat surface, it took about 2 rides to groove back into the rotors and it was at that point when the rotors really kicked in hard.
    Should do that as you may know on a semi-regular basis after really hard riding or really dirty muddy conditions. OH...is your fork a 20mm affair or a skewer mate...? It does make a huge difference, especially if you are running a massive 8"-er up front.
    Hi!
    What do you guys think are the best pads for the 4pots.
    I had the original sintered ones, awesome stopping power in dry conditions, but unusable in the wet - no stopping power and squuuuuuuuuuuuuuueeealllllll.
    Now I am on some original Shimano resin pads. They seem fine. No noise, nice modulation.
    I could get a hold of Koolstop or Galfer pads, does anyone have experience with the Galfers? Heard good things about them.
    Greetings Znarf
    FM
    FM is offline
    Apr 2003
    Hi!
    Greetings Znarf
    I think your sintered pads may have been contaminated? We frequently ride in wet conditions and the resin pads just don't last long. I much prefer the metallic pads and have had no issues with squeal or braking power.
    Could be the case, or I didnt brake them in enough.
    I also changed from new 203mm 6-bolt shimano rotors to some Hayes V8s. The Hayes have bigger holes and I think that they clear out mud and heat a little bit better. But that may be just my imagination.
    When my resins are worn, Ill give the sintered pads another chance, or get some Galfers.
    Greetings znarf
    MTK
    MTK is offline
    Some Old shot's.
    The Super 8 shot is a brand new frame just built{second Frame}. The
    DerKerf shot is also old. I now run the Orignal Saints on the 8{rear only
    GoodRidge line.} The Hardtail is still 4 Pot's,{Rear GoodRidge}but I have dropped
    to a 180 Rear Rotor. I have the 8 4 Pots on a Intense now. The Super 8 cost me some
    coin as I had to buy a new rear Brake Therapy Mount. Great Brakes. I feel
    like I am missing the Bus with all the new stuff out,but I am so happy I cant
    see makin a change. Sorry if I confused you,hope you like the shots. Peace.
    MTK{I confused myself.}
    I sanded the pads, then cleaned off with the alcohol and noticed an improvement the first couple stops. I'm hoping once the pads re-bed in they will improve because the bite is not quite there yet, but allot better then they were.
    I'm going to do the back also just for the heck of it.
    Nov 2006
    Yeah with mine, as I said before it took about 2 really good runs down the MT to really bed-in those puppies as such, so bare with it and they should improve...especially now that you have already bled them with no air or contaminants in the line. I have the 8" Fr and 6" Rr set up as I had found the 8" Rr way too much stopping power and I was really locking up when I just wanted to control my speed.
    But I clean mine in this manner regularly - minus the bleeding of course, that more of an annual or bi-annual thing again, case by case.
    hi all,
    has anyone tried using M755 front clipper on the rear?
    will i be able to run 140mm rotor?
    looking for a nice cool 140 setup for my street bike...
    John Galt
    Reputation: cegrover's Avatar
    More pics. I'm definitely a fan of these brakes, too...
    Brand new Front XT 4pot paired with XTR levers.
    Love 'em
    My bike, a 2006 Cannondale Bad Boy Ultra:
    <a href="http://smg.photobucket.com/albums/v311/ecox/?action=view&current=DSC07705.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v311/ecox/DSC07705.jpg" border="0" alt="Photobucket"></a>
    Close-up, XT 4-pots. For fun I replaced all the bolts with titanium:
    -Erik
  67. #67
    I've used them, and I don't like them. They feel fine, but the setup required for them sucked. The pads have very little travel, and there's no centering adjustment, so the only way to tweak them is with very thin washers between the frame and caliper, and even then you're probably still going to get rubbing. Hopefully this summer I'll remember to throw the set is my spare parts box up on eBay...
  68. #68
    Quote Originally Posted by bad mechanic
    Oh I have to do this..............
    Maybe if you weren't such a bad mechanic, you could set these brakes up with better results.
    BTW, I like mine.
  69. #69
    Nov 2006
    Not to be rude here, but it really does sound like you have not set them up properly.
    I say this because when they ARE set up as they should be, they are some of the BEST brakes on the market today and many racers and various others use them even when it does come with a minimal weight gain...the performace outweighs the scale factor here.
  70. #70
    No, I had them set up right. I didn't say they didn't perform well, because they did, but the hassle was enough that I didn't want to deal with it. I feel there are other disc brakes out there which work as well, but are much easier to work on.
  71. #71
    Nov 2006
    Well there is no dissagreement there mate, that is for sure. Although the XT4Pots are in my mind, very easy to set up...but, there are others out there whose set up is by far easyIER. Erm...I have already told you I liked hope, did'nt I? he he he.
  72. #72
    Ultimated Outsider
    Reputation: sundowner's Avatar
    4-pot goodness
    I found a pair of brand spanking new caliper and could not resist to go back to them. I am using them with XTR lever and Gooridge lines and G+pads. 102_1557.JPG
    If I disagree with you, it's because you are wrong.
  73. #73
    dirt visionary
    Reputation: clockwork's Avatar
    Love my 4pots. I have had them a few years while having other brakes also and these are my favorite.
    Life should NOT be a journey to the grave with the intention of
    arriving safely in an attractive and well preserved body.
  74. #74
    Reputation: Fuel53's Avatar
    Nov 2006
    I just bought a new in the box pair of M755- levers/calipers/160 rotors/2 bleed kits-2006. I didnt realize the caliper size was so big and the mounts were different. I wanted to hook up M775 levers on there with the 4 pots but I really dont have the time to track down the various adapters and all at the moment, barely have the time to ride right now. Would anyone be interested in them?
  75. #75
    Nov 2006
    Your better off keeping them and being patient for the mounts, they're easy to spec'n'get. Really, once these brakes are set, you can mainly forget them, they need far less maintenance than MANY others due to the oil used because they weep less and are far less hydroscopic.
  76. #76
    Nov 2006
    I know they are great brakes, I will have to live with the stroker trails for now. Just sold them. No time or money to tinker. Better to ride now with a great bike than waaay later with the perfect bike!
  77. #77
    dirt visionary
    Yeah I have strokers(3 years) on one bike and while they are the best hayes brake I have used. However they aren't as powerful or have as good modulation as my grimeca's and 4 pots.
