Results 1 to 2 of 2
    aka Willy Vanilly
    Reputation: will8250's Avatar
    Aug 2003
    XO Trail Caliper to Elixir CR Lever?
    Go or no go? I remember reading some of the older stuff (Code caliper to Juicy or Elixir lever) would work but how about the four piston XO trail caliper to the Elixir CR Lever?
    Will the lever push enough fluid? Trying to get some firsthand knowledge before trying it, having it not work, then having to potentially get new parts. Thanks
    Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction.
    E. F. Schumacher
    sXe
    aka Willy Vanilly
    Aug 2003
    Since no one replied, I called SRAM.
    Frankenbrake should be fine.
    If not, they sell a kit to change the reach adjust from tool-less to tooled (sans knob).
    E. F. Schumacher
    sXe
  1. Shimano Lever and Caliper?
    By bikeguy27 in forum Brake Time
    Last Post: 07-21-2012, 11:46 AM
  2. Mixing old caliper with new lever
    By Slurry in forum Brake Time
    Last Post: 04-01-2012, 02:31 PM
  3. Quick one...Lever/caliper mix
    By cale399 in forum Brake Time
    Last Post: 01-27-2012, 06:28 AM
  4. XTR M975 caliper with SLX M665 lever
    By Midle Age Warrior in forum Brake Time
    Last Post: 06-06-2011, 06:54 PM
  5. xx caliper vs elixir caliper
    By slimat99 in forum Weight Weenies
    Last Post: 05-22-2011, 09:06 AM
