Results 1 to 7 of 7
    XO gripshift and Hope M4s?
    Has anyone on this board made this combo work? The M4s levers are short and I am pretty sure that there wont be enough room to grab the levers with the XO gripshift.
    Getting longer levers is an option but I like the stock levers.
    Thanks.
    Reputation: drumstix's Avatar
    What about the mini grip?
    bike weenie
    Reputation: RWGreen's Avatar
    Dec 2004
    I run that combo and have no reach issues...
    no problems
    I don't really understand what you are concerned about. I run my M4 and mini levers about 1 or 2 cm inboard from the the gripshift, and the lever still covers about half the grip. i use 2 fingers for braking. if you used only 1 (your pointer finger), you'd probably move it further in than that. What, do you want to brake with all 4 fingers or something?
    Negative Rep Points!!!!
    Reputation: Aquaholic's Avatar
    Works for me.
    Run it.
    What the EFF is "All MOUNTAIN"???
    Reputation: mtnbiker1973's Avatar
    Another reason to switch to shimano........ (I'm just kidding, by the way)
    Boyeeee
    Reputation: BCBlur's Avatar
    I ran this setup on my Blur for a while and had no problems.
    Recently I changed levers to some Dangerboys and like it them considerably more than the stock Hope levers (which I also liked). The Dangerboys are shaped a little better, are gripped, and are longer.
