Results 1 to 2 of 2
    Dec 2011
    Would Shimano Zee’s work well with a 160mm rotor?
    Just wondering if a Zee caliper needs and adapter for a 160mm rotor or will it bold directly to a post mount fork?
    B A N N E D
    No adapter needed if the post mounts are set at 160mm specs, if on your fork you use a 180mm adapter with a 180mm rotor or a 203mm adapter with a 203mm rotor then your fork will has 160mm post mounts.
    Some forks have post mounts set at 203mm specs, with these a 203mm rotor is the smallest rotor that can be used.
  1. 160mm vs. 180mm rotor Pro/Cons?
    By Badassbassangler in forum 29er Bikes
    Last Post: 04-10-2014, 09:49 AM
  2. Replies: 2
    Last Post: 09-02-2012, 09:58 AM
  3. Replies: 1
    Last Post: 08-01-2012, 10:01 AM
  4. 160mm rotor on 29er?
    By carpy95 in forum 29er Bikes
    Last Post: 10-18-2011, 11:25 AM
  5. Replies: 39
    Last Post: 05-25-2011, 06:14 PM
