Results 1 to 5 of 5
    will a reverb bleed kit work for Forumla RX brakes?
    I've got an extra, clean Reverb bleed kit. I think I need to bleed my Forumla RX brakes (they seem to require a more force at the lever than they used to after about 1 1/2 years).
    Anyhow, the kit I have looks a lot like the one in the pictures here:
    Tech Tuesday
    Just to make sure I don't accidentally screw things up - can anyone share any experience with this?
    Thanks for any thoughts.
    Plays with tools
    Reputation: customfab's Avatar
    I've used those fittings to bleed other Formula brakes but never the RX. But i've got to imagine they use the same fittings.
    thanks! I'll give it a go.
    Reputation: Bubba74's Avatar
    Feb 2007
    Did this ever work? I'm having problems threading a reverb syringe into an RX lever. I think I might have stripped it
    I've got Formula R1's and the fitting for the leaver side needs to be different than most of the other bleed fittins out there...not sure about rx's tho
    MyRides - Santa Cruz Tallboy CC, Van Dessel Ramble tamble SS, Look 986 1x10,
  1. Rock Shox Reverb IFP Bleed Procedure?
    By kroe in forum All Mountain
    Last Post: 01-31-2017, 09:38 AM
  2. Reverb remote replacement bleed screw
    By opiants in forum Turner
    Last Post: 12-28-2011, 12:42 AM
  3. Reverb remote replacement bleed screw
    By opiants in forum General Discussion
    Last Post: 12-25-2011, 12:28 PM
  4. Reverb Xloc brass bleed fitting source?
    By damagr in forum All Mountain
    Last Post: 10-24-2011, 12:49 PM
  5. Elixir bleed kit ok to use with Reverb Seatpost?
    By manamana in forum General Discussion
    Last Post: 08-05-2011, 06:27 PM
