Results 1 to 3 of 3
    Reputation: djork's Avatar
    Will Hope 160mm 2-piece floating rotor work with Avid BB7
    for front brake set-up? Fell in love with this piece of rotor blinginess!
    well i know they can be ran on XTR no problem ive got the same query want to set up a hope 2 peice floating rotor on juicy 7's for my dirt jump would be nice to know if the 2 piece rivets or what ever they are rub on the caliper?
    other wise thickness is fine and other issues only problem you may have is that it the bolts that connect the 2 pieces together may rub on the caliper but i would like to know if this is the case and if some one has run it?
    To be honest, and it's not a shot, the rotors aren't terribly cheap alone and it makes more sense to buy a set, either new or used, depending on your budget. While BB7's are fine brakes, it's still like putting 4,000 dollar rims on an 1984 Celica (and I don't mean the bike). The BB7's aren't so blingly, with their rough finish and their red knobs, and on top of that, even if they fit, you're not really going to get some braking improvement.
