Results 1 to 5 of 5
    Nov 2006
    Will this combo work?
    Avid BB7 Calipers
    Shimano 585 Centerlock hubs with Shimano centerlock (RT-62) rotors
    Any reason that wouldn't work? Will I have to play with spacing on the calipers to get it to line up or will this just drop right in and work like a champ? I guess it comes down to lateral and vertical alignment, right? Any incompatibility issues?
    I know they make adapters so that centerlock hubs will accept 6-bolt rotors, but I'm wondering if the above setup, using centerlock rotors, will work.
    Thanks -
    Nov 2006
    Somebody must know if this will work??
    Any help greatly appreciated.
    offroader
    Dec 2008
    as long as the rotors you're using matches the fitting for the brake adapters I don't see why not.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    shimano rotors usually have a thinner braking path than other brands, so you might get uneven pad wear....
    a buddy of mine has had luck with the new XT rotors and formula brakes (seems like the new centerlock XTs have a bit wider area than the 6 bolt XTs I run...)
