Results 1 to 9 of 9
    I like Monkeys
    Reputation: VaughnA's Avatar
    Why not floating calipers
    With all the trouble of alignment why don't we see more floating calipers in the bike world? I think the magura gustav's use them but no others that I know of. It is common to have a single piston, fixed pad and floating caliper in the car world. It seems to me that a single piston, floating caliper brake would be more reliable and easier to align than the current dual pistons with about the same weight. It would also handle warped disks better.
    Just Askin'
    What do I want to be when I grow up.....Dead!
    Reputation: Curious-George's Avatar
    mounting options maybe? no clue tell you the truth
    nnn
    nnn is offline
    Reputation: nnn's Avatar
    Feb 2005
    I'm guessing something about licensing/patent costs that manufacturers don't think are worthwhile paying
    "Life begins at 140" Richard Burns
    http://www.nikolay-k.com
    I like Monkeys
    Quote Originally Posted by nnn
    Magura is using sliding calipers on the gustav. If there is a license I'd think it would be cheaper than the machining and parts for a 2nd piston.
    My only thought might be mud, but I'm sure there is a way to make a weatherproof slide.
    LDH
    LDH is offline
    Reputation: LDH's Avatar
    opposed piston calipers negate the need for caliper movement , single action calipers need floating mounts EXCEPT on bicycles where the rotor is deflected over to the fixed pad.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by VaughnA
    Just Askin'
    Floating calipers actually rub more than fixed.
    Motor vehicles can tolerate draggy brakes more than bicycles.
    Floating calipers/rotors on a bicycle constantly rub/jingle and there is not thing you can do about it.
    mtbtires.com
    I like Monkeys
    Quote Originally Posted by shiggy
    That answer makes sense. As much as I hate the least drag I'm guessing that I'd never tolerate the rubbing on a floating system.
    mbtr member
    Reputation: scottzg's Avatar
    floating calipers rely on the rotor to keep them centered, a thin mtb rotor would bend before the caliper moved. If the sliders were so smoothly operating that the caliper could be slid by the rotor, it could easily be bonked back out of alignment by the trail. Maintaining the slider pins (they would have pretty tight tolerance to function in these conditions) would be more of a nuisance than setting fixed calipers correctly. The caliper sliders would add weight, complexity and cost.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Well, with the airlines I fly, there are only pistons on one side of the caliper, pads are on both sides, but if there was no floating caliper, the disc would warp the rotor when you used the brakes, so by allowing the caliper to float, you don't warp the rotor and it stays centered. This also allows for a simple design that is still essentially a "one-peice" caliper, but it cuts down on all the design/cost/extra seals associated with a 2-peice caliper, or even a 1-piece that has opposing pistons.
