Results 1 to 10 of 10
    why are my XT/SLX disc brakes squealing?
    XT ice tech front and SLX on the back. SLX rotors all around. I've ridden about 50 miles total in dry conditions. Today I got rained on and oh man! The noise was loud!
    does that indicate a problem?
    I noticed that when the rain stopped and i'd done some braking, the noise subsided. I'm guessing the heat dried the rotors. but then when i got hit with another round of wet, the noise was back.
    Oct 2012
    Wet discs brakes are loud. As you say, heat from braking dries them out and quiets them.
    Never had that problem with my avid bb7s. Figured these would be the same. Guess not...
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Wait until you hear a set of Hope's in the wet . . . it's pretty normal for brakes to squeal when wet. How loud often depends on the pad compound and the rotor design, as some are worse than others.
    Reputation: 006_007's Avatar
    Yup, different brakes respond different to the wet - my experience I have found my Magura Gustavs were the quietest, followed close to an old set of hayes 9 I used to have. Magura lousie and martas were a bit louder. Shimano XTR are noisy in the wet. Avid elixers I used to have were noisy in the wet and in the dry.
    MTB B'dos
    Reputation: LyNx's Avatar
    As said it's normal, but you could also have built up a layer of film in the dry and when that gets wet. My XTs were fine for a good while, but then any time I got near the sea with salt spray they'd holler, but not if just rain/water wet. Started happening when just when, so figured I'd built up some contamination or some such so gave them a little clean with alcohol and light sand, cleaned the rotors with alcohol as well, noise has gone away.
    not possible. only avid hydros squeal, not shimano
    2015 Santa Cruz 5010 C
    AKA Mr.Habanero
    Reputation: panzer103's Avatar
    I have some new XTs and some 2 piece shimano rotors. And from Day one they shriek. like, wtf! Im sure i didnt brake them properly and. There is a slim chance i might of got some brake fluid on them but l cant say for sure. But power is bad and the squeal is un real. Bad from the first day.
    Oct 2012
    I think you figured out why your brakes squeal. If you didn't brake them in properly AND you got oil on them, then it is no surprise you don't have power and it squeals. You should always clean the rotors with isopropyl alcohol after doing anything with them as you're bound to get oil from your hands, tools, etc. on them. Pickup a new set of pads and bed them in properly and you'll have plenty of power.
    How many miles have you put on them so far?
    May 2013
    I've recently fitted XTs to my bike, it rained today and they squealed pretty loudly. My old Br-445s squealed as well in the wet and snow. I had heard that Shimano brakes were supposed to be quieter than others? Guess not...
  1. Washed my bike. Now disc breaks are squealing
    By Gregdpw in forum Brake Time
    Last Post: 04-19-2012, 09:04 AM
  2. squealing front disc
    By HardyWeinberg in forum Fat bikes
    Last Post: 01-17-2012, 01:48 PM
  3. Brakes squealing horribly! (2011 XTC 1)
    By trumpus in forum Giant
    Last Post: 05-16-2011, 07:15 AM
  4. Squealing disc brakes?
    By Ozark-XCrdr in forum General Discussion
    Last Post: 02-20-2011, 01:33 PM
  5. Squealing Disc Brakes
    By 1SPD in forum Beginner's Corner
    Last Post: 01-25-2011, 09:52 PM
