Results 1 to 67 of 67
    why do bigger disc's equal better stopping??
    Sorry for the stupid question but I am realitively new to the disc brake world.
    Why, all things equal (best I can tell is the same model with 160mm vs 185mm still uses the same pads, caliper etc) does a bigger disc diameter equal better stopping. The pads still only bare on the outer1/4 of the disc.
    Is it that there is more baring surface due to the larger diameter or better heat discipation, both (neither lol).
    Thinking about putting a 185mm (up from 160mm) upfront for next year (with the correct bracket ofcourse) so I want to make sure I know why it works better, lol
    J-
    The same pad and caliper grip the same amount of disk with the same pressure....
    Thing is the bigger disk can dissipate heat better...
    and it has a bigger lever arm to work with.
    The heat dissipation is the big thing.
    Weird huh?
    Reputation: cmdrpiffle's Avatar
    The unscientific answer is it takes less energy to stop a spinning wheel closer to the outside of its diameter. A larger disc effectively moves the braking area closer to the outside of the wheel.
    Someone will chime in on the science....
    Cheers!
    Poaching Demo...that's why we can't have nice things...
    Quote Originally Posted by cmdrpiffle View Post
    Cheers!
    The energy required to stop the bike remains the same regardless of the disk diameter.
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    Quote Originally Posted by jeffscott View Post
    Yes but you have a better mechanical advantage with a bigger rotor. It's not solely a matter of heat although it also plays a role. If we take heat out of the equation, the bigger rotor will still have more power.
    Check out my SportTracks plugins for some training aid software.
    One word: torque
    Quote Originally Posted by PissedOffCil View Post
    Yes but you have a better mechanical advantage with a bigger rotor.Yes a longer (bigger) lever arm It's not solely a matter of heat although it also plays a role. If we take heat out of the equation, the bigger rotor will still have more power.
    You are mixing your terms.....Power refers to energy per unit time. The brake converts kinetic power, to heat...and it must dissipate or store this heat. The bigger rotor will be better for both dissipation and storage of heat. So heat dissipation and storage provide more braking power.
    The lever arm provides greater braking torque because of the longer lever arm.
    End result bigger rotor equals more braking torque and more braking power.
    For me a 160 mm rotor provided ample one finger braking torque...(I could do a really good stopee)....but on long descents I would smoke the brake and lose braking torque due to overheating.
    So for me the bigger rotor 203mm improved the braking power by increasing heat dissipation/storage.
    Master of the Face Plant
    One word: Leverage (which basically means torque)
    http://www.nbbikes.com/
    ^^^Best Bike Shop of MTBR 2008^^^
    Reputation: henry9419's Avatar
    Quote Originally Posted by sandmangts View Post
    +1 think of it as a lever on a fulcrum and you are trying to lift a large weight if you have 10ft of lever on your side of the fulcrum it will be easier to lift the weight then if you have 5ft on your side
    Did i make any sense?
    so if you have a larger rotor you then have a larger lever so to speak which makes it that much easier to stop the bike.
    2009 Jamis Trail X2
    2002 Raleigh Mountain Scout
    2008 Trek fuel ex7
    Binned
    Nov 2008
    More surface area to compress upon...
    "bigger is better"....oh, baby!
    cool thanks guys all makes sense and was kinda what I was thinking.
    Second quick question. To go to a bigger front rotor all I need is the rotor itself and the appropriate caliper adaptor?
    Same cailper/pad would work, correct? I have BB5's, if that matters.
    J-
    Binned
    Nov 2008
    Yes, make sure to get the proper FRONT adaptor.
    Quote Originally Posted by ambassadorhawg View Post
    copy thanks all for ur input.
    J-
    Check if your front fork will support the bigger rotor. I wanted to upgrade but RockShox said that my fork wouldn't support the bigger rotor. I assume the fork didn't have enough support for the extra stopping power or something.
    Quote Originally Posted by adrianmoisey View Post
    copy i'll def check that before I lay out the cash.
    thanks
    J-
    Old Punk
    It's torque and surface area. The torque has been explained. But on the larger diameter, more rotor passes through the caliper with one rotation of the wheel. More circumference = more brake length for the same distance traveled. A 160mm has 502.654mm of braking length and a 185mm has 581.946mm, that's an extra 3" of brake per revolution.
    Btw, circumference = pi x diameter.
    Oh yeah, and better heat dissipation.
    '09 Specialized Rockhopper expert 29
    Born 26" trials
    '07 Specialized Allez
    g3h6o3
    Oct 2007
    I'm not mixing terms at all. Mechanical advantage is the same as leverage and this is what gives you better stopping power with a bigger rotor.
    From Sheldon :
    "'Mechanical advantage', or 'leverage' is the ratio between how much you get out of a linkage and how much you put in."
    "Installing smaller wheels [... reduces] the mechanical advantage accordingly. For instance, substituting 622 mm (700C) wheels on a bike built for 630 mm (27 inch) wheels will degrade the braking."
    The same applies to rotors.
    Ref : The Geometry of Cantilever Brakes
    From Sheldon :
    He's trying to point out that you are using the word "power" in the wrong context. Notice how neither of the statements you just listed reference "power"?
    g3h6o3
    Oct 2007
    Quote Originally Posted by kan3 View Post
    No his edited quote mentions that a longer lever gives better mechanical advantage, which it does but a bigger rotor also gives a better mechanical advantage.
    Yes I used "power" as in "stopping power". Given the context I think it goes without saying and without getting into semantics.
    Reputation: bamwa's Avatar
    nice ^ ! way to sum it all up.
    Keep trying to do the awesomest thing you've ever done.
    No his edited quote mentions that a longer leverlever arm as in the radius between the brake pad and the axle gives better mechanical advantage, which it does but a bigger rotor also gives a better mechanical advantage.
    Nope still got it wrong but what the hey....you at least can understand yourself.
    Reputation: JanBoothius's Avatar
    Have you ever extended the handle of a tire iron to make it easier remove lug nuts?
    I believe a bigger rotor works on the same principle to provide more stopping power.
    Quote Originally Posted by JanBoothius View Post
    Yup the extended handle, gives you a longer lever arm....hence more torque....not more power.
    Anyway we call that a snipe around here.
    g3h6o3
    Oct 2007
    What exactly are you talking about? Are you saying that a bigger rotor doesn't have a bigger mechanical advantage over a smaller rotor?
    g3h6o3
    Oct 2007
    You're really just playing with words. When people talk about stopping power, they mean the ability to stop in a shorter amount of time/distance from a given speed. You can go around correcting people with your torque vs. power all you want, it really makes you look like a dork... Everybody here understood what we are talking about, we couldn't care less about your semantics and uptight comments.
    No not at all that is correct...
    The bigger rotor locates the caliper and pad further away from the axle....this results in a longer "lever arm" for the same force to act upon....
    Hence more braking torque (notice the words "lever arm", that is a precise engineering term to describe the length of the radius upon which a force acts to develop a torque....not the brake lever).
    Second Brake Torque is not Brake Power.
    A brake must dissipate the Kinetic Power into Heat without overheating and fading.
    That is governed by heat storage, and heat dissipation both of which are also higher with a bigger rotor.
    You're really just playing with words. When people talk about stopping power, they mean the ability to stop in a shorter amount of time/distance from a given speed. You can go around correcting people with your torque vs. power all you want, it really makes you look like a dork... Everybody here understood what we are talking about, we couldn't care less about your semantics and uptight commentsClearly some do, also clearly you don't.
    Not at all the point is that brake torque and brake power are two very different things is quite important...
    For example with Shimano's ICE technology you can get a smaller, lighter brake (smaller rotor diameter) with equivalent power (because they have installed a heat sink on the pads)to a brake with a larger rotor, but less brake torque (as long as the brake levers etc are the same).
    Precise language often helps clarify ones understanding of issues
    More metal passed through the friction material ( pads ) for a given wheel rotation, which ='s more friction, simple.
    Bigger rotors also heat up slower cause they generally have more material to heat and disipate the heat faster due to the higher surface area.
    Math's wise the faster your going the more energy you need to be stopped.
    Kinetic Energy = weight * ( Speed ^ 2 )
    Thankfully as you get faster your friction increases.
    Friction = Rotor Speed ^ 2
    So you have a equal lever force requirement at 30mph as you do at 15mph pretty much ommiting some small variables. Despite at 30mph having 4x's the kinetic energy.
    Reputation: TheNightman's Avatar
    Aug 2010
    Quote Originally Posted by Turveyd View Post
    ^ This is what it all boils down to. Given the same calipers (implying equivalent "squeezing" force) and the same rotor and pad materials (implying an equivalent coefficient of friction), the only difference is that for one wheel rotation the caliper will be applying friction to the larger rotor across a longer distance. For any given speed, the caliper needs to apply it's frictional force through the same distance (the arc length of the rotor in this case) regardless of the rotor size; the difference between the two cases is that for a given arc length, the smaller rotor needs to go through more full rotations than the larger rotor, which means that the wheel will needs to go through more rotations and you will travel farther before coming to a stop.
    Quote Originally Posted by TheNightman View Post
    Yep, most people think it's leverage how far the caliper is out, although leverage is a part, the bigger the lever the more pressure you can apply to the pads, they can't call it a brake lever for nothing
    29" Wheels, need 10% bigger rotors for the same power as you travel 10% further for the same amount of friction, 29ers with 160's rotors is the same as 26" with 144mm rotors power wise, not heat wise though still 160's.
    Energy is the ability to do Work. Work is Force x Distance x the Cosine of the angle. The pads always make contact at 90 degrees to the hub, and Cos 90 is 1.
    So W = FD
    The only way for a brake to do more work on the rotational energy (momentum or mass times velocity) of a spinning wheel is to either increase the Force (4 piston brakes, better design, etc) or increase the distance of the lever arm. A lighter wheel has less momentum since it has less mass but that's off topic...
    What's next? Rim brakes?
    Quote Originally Posted by SJDude View Post
    So W = FD
    4 pistons on there own do not equal more power, they may allow you to have a longer pad which isn't as deep which sits further out on your rotor and gives you a fraction more power also the 1 side can generally move before the other to get rid of snatch at first then you can run more pressure to the piston.
    say 400grams off both rims / tyres compared to a 200lb person and bike which is 90,800grams allowing for the rotation is likely 0.6% factor in aerodynamics as your speed increases and this drops considerably.
    Brake Force = ( ( [1/2 Pad Radius] * 2 ) * Pi ) * [Friction] ) * ([Rotational Speed]^2)
    [Friction] being a variable 0 for not in use and up ofcourse,
    Hence, narrower longer pad gains you a few mm's in effective rotor size.
    If you used a Planetary gear system on your hub to disk you could double the rotor speed and get double the power, but at a weight cost.
    g3h6o3
    Oct 2007
    Now let's factor in pad material...
    That is actually ingenious. Overly complicated but should work.
    Old Punk
    Hammerschmit idea + disc brakes = downhills newest money pit
    Born 26" trials
    I was curious how this question rcvd so many responses. Now I know and I want my 2 minutes back. ; )
    Nov 2007
    [DEleted]
    Oct 2010
    not entirely sure, but i believe the bigger the rotor, the more rotor contact with the pads, allowing for better stoping power.
    Also, the ability of the larger disks, to have more time to cool down, inbetween points.. So like lets say a 180mm disk takes 1 sec to do a full rotation (A to B).. So 260mm disk takes about 3sec to do a full rotation (A to B)..
    That is my belief.
    It's not contact with Pads area although bigger helps, as your same force through the lever is just spread over a wider area.
    And Pad Material changed the Friction value, increasing or decreasing.
    And yes, having your rotor spinning at 100mph when your doing 20mph would look cool!!
    Reputation: Fix the Spade's Avatar
    Right until you fall off and get a finger caught in it.
    Or until the caliper explodes...
    Although, having a gearbox where the casing rotates with the output drive would be awesome!
    Quote Originally Posted by Fix the Spade View Post
    Well always downsides, but proves nicely it's not the stupid leverage most people think it is.
    Wouldn't generate any more heat maybe cool better as it's spinning so fast, heat is just kinetic energy of your movement being transfered to heat, so speed = same heat generated.
    Old Punk
    Like I said, it's the amount of rotor that travels between the pads per rotation that's the rotor difference (brake length/circumference). That's why the planetary would work. Not sure why everyone had to overthink it. Sure leverage plays a part, but not as much as the extra 3" of rotor passing through the caliper from 160 to 180.
    Born 26" trials
    Quote Originally Posted by curtboroff View Post
    I'm with you on that, the only place where leverage comes into it on a disk brake system is you guessed it the Brake lever, thats why it's called a lever, the leverage there lets you compress the pads via the fluid.
    You can't science wise use Leverage based on distance from QR, although the calc works out the same it makes no allowance for Friction and assumed brake always on or ability to increase the power relative to the riders speed.
    People are moron's and repeat the first thing they hear with no ability to change or rethink it most of the time. Even when the subject is obviously way above there tiny little brains.
    Sorry it's a arguement I had on another forum with everyone stick and so called mates, still sniggggers ( can't say the N word LOL ) and say leverage like they are correct even today 1 had a pop today and said unable to admit when I'm wrong, which is kinda ironic as he's wrong.
    People!!
    I'm with you on that, the only place where leverage comes into it on a disk brake system is you guessed it the Brake lever, thats why it's called a lever, the leverage there lets you compress the pads via the fluid.The lever arm referred to is the mechanical advantage of the system
    You can't science wise use Leverage based on distance from QR, dam right you can although the calc works out the same it makes no allowance for FrictionWhat units and assumed brake always on or ability to increase the power relative to the riders speed.
    Same difference boys...think it through.....Oh and BTW brakes still overheat....
    Holy Cow, havent checked in this thread in a while, suffice to say my question has been anwered, LOL
    Got an 180mm adaptor from North Shore Billet on the way and picking up a 180mm avid HSX two piece rotor from Tree Fort tomorrow.
    J-
    There calc, the caliper would have to move in and out to vary the power LOL
    And 100mm caliper position with a bolt through or 200mm with a bolt through both has exactly the same effect on the wheel, it won't move, Leverage can only count when the disk is locked solid within the caliper.
    Thats only then useable to work out the strength needed from QR to Caliper.
    Nov 2007
    Do you actually know what you're talking about? You seen to be very forthright and you seem to be suppressing others' contributions.
    On this basis I won't join in the debate any further than to say I think you are incorrect on a number of levels and your equations are pretty much all bogus.
    Leverage? I'd say think again because you're way off base. Thing is you are so convinced of your correctness I can't see room for a reasoned debate.
    Just saying.
    Sent from my GT-I9100 using Tapatalk
    g3h6o3
    Oct 2007
    Saying leverage has nothing to do in the equation is stupid.
    Starting from the beginning:
    breaking is applying force by friction.
    This force is transferred from the disc to the ground through torque.
    The torque is calculated as: torque = (caliper traction force) * (distance from wheel center)
    So for a given caliper, the bigger the distance of the caliper from the wheel center, the bigger the torque applied!
    Now, as other users mentioned above, there are other factors that come in the equation "breaking" such as heat dissipation, clamping caliper force, area of contact, materials etc. Those factors directly influence the force applied to the disc and can equally affect the breaking power (torque).
    Heat Dissipation
    the more heat you can send out of the caliper-disc group, the more constant will be the breaking.
    Clamping Force
    it has to do with the force applied from the caliper itself from the hydraulic system. The force from our fingers is transferred from the hydraulic pump on the lever, through the pipe to the caliper piston. The size of the hydraulic pump, the lever geometry, the pipe stiffness, the hydraulic liquid, the piston diameter and the stiffness of the caliper have their role on the force transfer from finger to caliper.
    Contact Area
    The contact area transferrs the force applied from the caliper to pressure! For a given caliper force, the bigger the contact area, the less the pressure applied and the bigger the heat transfer gets.
    Now, it gets very complicated not only for us but for the designers and manufacturers of breaks to understand all these parameters and fit them to a bike with the less weight possibble having the bigger breaking torque applied.
    Bottom line
    If one chooses a break type (caliper, lever) that fit ones needs, for a bigger force, will choose bigger disc and for lesser force smaller disc.
    I hope this description sums up all the above.
    g3h6o3
    Oct 2007
    I hope we can move on, this thread should have ended at the 2nd post.
    The primary function of a braking system is FRICTION not leverage, without friction there is no leverage, with a change of friction the leverage changes so why bother with the out dated leverage static calculation.
    140mm or 203mm if you can apply enough force to lock the disk the effect on the front is both equal you go over the bars, so more 'leverage' same result, proves how pointless doing is as a leverage calculation is.
    I <3 dirt
    Reputation: Ilikemtb999's Avatar
    Oct 2010
    Quote Originally Posted by gfourlias View Post
    Heat Dissipation
    Clamping Force
    Contact Area
    Bottom line
    You can try and look as smart as you want but you look like a dolt spelling brake "break"
    Quote Originally Posted by Ilikebmx999 View Post
    We completely ignore him due to a spelling eror then, just cause it doesn't agree with your thoughts.
    Forums and People!!
    Doh Given the same "friction" (more precisely frictional force) ie same squeeze of the pad on the rotor.
    The bigger rotor applies more braking torque....
    By 203mm/140mm or 1.45 more braking torque...
    quite simple actually.
    g3h6o3
    Oct 2007
    Except for a minor detail: you don't need the same force at the lever to lock different size rotors...
    Now lets move on shall we?
    And the increased metal from the rotor moving through the pads increasing the friction created is nothing to do with it then.
    Increased friction = more torque, primary is still FRICTION!!
    Try to say it properly and you will have the answer....
    I have already done the math and there it is:
    203/140= 1.45 times more torque
    203/160 = 1.27 times more torque
    203/180 = 1.13 times more torque
    180/140 = 1.28 times more torque
    180/160 = 1.12 times more torque
    160/140 = 1.14 times more torque...
    Heat storage will follow the same rule pretty closely....
    Heat Transfer is a little more complicated but again use the same rule....
    I think I know very well what the maths work out at, it's the application which is in error, your method has zero ability to increase the power as your speed increases.
    Yours is a static calculation mine is dynamic, mine increase the power relative to the speed of the bike, remember the bike as it goes faster how more kinetic energy,
    Remember E = MS^2 so at 20mph you require 4 times the braking force as 10mph.
    Mine is the proper calculation!!
    Nov 2007
    What units [FRICTION!!] ?
    Talking about primary or not is a pointless. Think in terms of frames of reference and you don't need to be a big bully claiming your view is more important than anyone else's.
    What units [FRICTION!!] ? In your equation:
    ...it turns out to be MASS (S.I. unit kg).
    In what text book did you ever see friction described as a mass? Basically you've got the basics completely basically wrong. So stop making something really simple complicated.
    Braking converts kinetic energy to heat. More effective braking converts more kinetic energy per second. Therefore the braking POWER needs to be high (POWER=ENERGY/SECOND).
    POWER=TORQUEx ANG.VELOCITY
    TORQUE=ROTOR.RADIUSxFRICTION.FORCE
    i.e.
    POWER = ROTOR.RADIUSxFRICTION.FORCExANG.VELOCITY
    In the question asked by the O.P. we can see that ANG.VELOCITY and FRICTION.FORCE remain the same. The only thing that changes is the ROTOR.RADIUS.
    Now it also happens that ROTOR.RADIUSxANG.VELOCITY = the linear velocity of the rotor past the pads. So by changing the frame of reference you get an equally valid equation much closer to the one you have been going on about:
    POWER=FRICTION.FORCExLINEAR.VELOCITY ...only this is much less useful for telling you what change you get from changing the rotor radius
    You have been promoting an argument about primacy between two variations on the same equation (and coming up with spurious stuff besides).
    I'm with Pissedoffcil. This thread should have stopped after post 2.
    Remember E = MS^2 so at 20mph you require 4 times the braking force as 10mph.Energy is not force
    Braking torque is what I calculated....Power is proportional to RPM X torque so there you go.....
    Oh and BTW Energy is not the same as force so you need to work on you engineering skills
    g3h6o3
    Oct 2007
    Quote Originally Posted by petercarm View Post
    In fact it should have been post 3 since post 2 only talked about heat, missing a big deal of the physics.
    Nov 2008
    Hey I was just thinking about this whole leverage and braking thing. Don't you stop faster when putting the most pressure on the brakes WITHOUT locking the wheel?
    If this is true, then having a larger diameter rotor allow you to squeeze your brakes harder without locking the wheel, therefore creating more heat from friction since you'd be squeezing the brakes harder. I thought of this by thinking of a bike upside down, if you locked a 160mm brake and tried moving the wheel by gripping the tire, then you'd have a lot of leverage over the rotor, but a bigger rotor would reduce your leverage, requiring more braking force to lock it up.
    ...I hope this makes sense, I'm just a 17 year old who loves to bike LOL
    Quote Originally Posted by justinbuzar View Post
    100% the opposite way, advantage of a bigger rotor is you haven't got to squeeze as hard then you've got more hand control and less likely to lock it up, but if required you can lock it up easier, if you get the desire to do a superman over your bars that is
    Nov 2008
    Ohhh ok thanks! I knew I was on to something haha
  67. #67
    Oct 2010
    cool cool, i am also 17, who loves to bike.
    Anyways, i dont think the pressure is really related to how well you can stop with a larger dia. disc. Because no matter what, i believe the lever preasure is more of a linear friction onto the disc, no matter what size the Dia. of the disc is..
  1. Bigger rotor or bigger caliper for my Hope?
    By john85D in forum Brake Time
    Last Post: 03-24-2009, 01:50 AM
  2. Bigger Tires means bigger tubes?
    By whos that guy in forum Wheels and Tires
    Last Post: 12-19-2008, 05:57 PM
  3. Equal work, equal pay?
    By Shakenbake in forum Endurance XC Racing
    Last Post: 01-16-2008, 04:15 PM
  4. DTC vs Stick-E, Bigger front tire vs Equal Size F/B
    By Jank in forum Wheels and Tires
    Last Post: 08-20-2005, 07:39 AM
  5. Help me!!! For I think I need disc's...
    By New2Mountain6 in forum General Discussion
    Last Post: 12-14-2004, 05:04 PM
