Results 1 to 7 of 7
    Who makes BEST brake lines for Avid BB-7 ???
    should i use Avid flackjacket or full metal jacket
    OR jagwire ripcord? or something else?
    ...but nokon's are out of the price question.
    One Gear
    Reputation: .40AET's Avatar
    Look for good aluminum ferruls and take the time to clean up the ends of the cables after their cut. I never had any problems with standard cables. Keeping them clean and lubed made a big difference.
    I just put BB7's on my Karate Monkey. I used standard Jagwire brake housing (full length) and used a dremel to cut the ends and file them off flat. With the ferrules on the ends, I've had no issues so far
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by eakins
    Nokon is the best but you do not need it. Standard Jagwire housing--full--length and installed well--works just fine.
    mtbtires.com
    I've been using Alligator I-Links full length on all my bikes. They work very well. I like them much better than the Nokon's. The inter-locking sections are much nicer to work with over the individual beads.
    ISO Flowy Singletrack!
    Dec 2008
    Another vote for standard cables and housing. A little TLC with cable cutting and you're golden.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    I agree, the Nokon cables are overkill. Why spend close the cost of a new brakeset, for cables? Even the Avid Full Metal Jacket, is more than enough, and offers smooth one-finger braking, and decent modulation even with Avid FR-5 levers.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
