Results 1 to 2 of 2
    where's the XTR sticky caliper info?
    My XTR hydro pistons are sticking. I did some searches but can't find the fix. It was written by DeVries (sp?)?? I've tried lubing the piston with mineral oil, but no luck. Should I lube with triflow or something else?
    Thanks for any pointers.
    (aka SS_MB-7)
    Reputation: 1speed_Mike's Avatar
    Quote Originally Posted by snowman3
    I had sticky pistons with my XTRs, too. They were recently warrantied (new calipers) and *seem* to be OK, but time will tell if they have the problem again. It took about 6 weeks for the problem to start.
    I tried everything to fix the problem myself, but nothing worked. Shimano USA stated that a light lubricant could be used on the piston surfaces to help. I tried Shimano Mineral oil and TriFlow...neither worked. In fact, the addition of lube to the caliper helped attract dust/dirt to the pistons...not good.
    Since I'm in Canada, I called Shimano Canada. They were well aware of the issue, but recommended NOT lubing the pistons for the reasons I discovered: it attracts dirt. Instead, they suggested cleaning the pistons with White Lightning Clean Streak. I did this and I didn't see any improvement. So, the brakes went back to Shimano Canada.
    Ride Hard,
    Mike B. (MCM# 7.77)
    http://www.one-speed.com
  1. Replies: 13
    Last Post: 01-30-2010, 11:53 PM
  2. Replies: 4
    Last Post: 04-12-2004, 07:40 AM
  3. How to remove housing from caliper and reinstall?
    By dawgcatching in forum Brake Time
    Last Post: 03-29-2004, 09:50 AM
  4. sram xo or xtr shifting?.........
    By marco in forum Weight Weenies
    Last Post: 03-15-2004, 02:37 AM
  5. Replies: 2
    Last Post: 03-09-2004, 04:06 PM
