    Reputation: mdb1974's Avatar
    Where online could I find bolts for my shimano breaks
    I have lx brakes. I need to replace two of the bolts that connect the bracket to the frame. Where can you find those?
    ...idios...
    Reputation: SteveUK's Avatar
    Your post is best suited to the Brake Time forum.
    If you're referring to the bolts that hold the caliper/mount to the frame, then they're a pretty standard M6 x 20 bolt (link) or (link). Caliper to mount may be shorter at M6 x 15mm. Either way, your local shop should have plenty of them floating around.
    Diogenes
    Vertical Member
    Reputation: UpRocks's Avatar
    Quote Originally Posted by mdb1974
    Where online could I find bolts for my shimano breaks?
    Why? Did they brake?
    Vaginatarian
    did you break your brakes
