Results 1 to 10 of 10
    Where to find a Shimano Carbon Brake Booster?
    Just wanted to see if anyone out there knows where I can find a Shimano carbon brake booster. I don't even know if they make these things anymore. Maybe someone has one collecting dust in their basment. I just built up a Sugar and because the seat stays do not have a bridge joining the two, the seat stays flex like crazy when my v brakes are applied. Thanks...
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    I still got a few of the liken carbon fiber boosters. Work way better than the shimano ones.
    <img src="http://206.75.155.18/kmr/bikes/liken.jpg">
    Reputation: scottms33's Avatar
    ummm
    you can always ask the lbs, or keep your eye out for one on ebay, i have seen a few there..
    scott
    DeeEight,
    Those look pretty nice. How much are you selling them? Any idea how much they weigh?
    Thx...
    Reputation: E-man's Avatar
    I've got one...........
    Quote Originally Posted by clubhomeboy
    I've got one that I'll sell you. E-mail me at ematheis@cox.net for more info.
    Eric
    Oakley - High Definition Optics
    Reputation: itsdoable's Avatar
    Carefull! I would not put a Shimano Carbon brake booster on the Suger until you've checked the clearance first. We put one on an early Suger (non-Plus) and at full suspension compression, the top of the brake booster will hit the seat tube. Put a nice little dent there. We replaced it with a cheap low profile Tektro brake booster, and it just clears, and still improves the rear brake feel.
    Cheers,
    Tom
    I didn't even think about that Tom. Thanks for the heads up. I'll check the clearance tonight.
    Eric: I'll email you once I know that it'll work. Thanks!
    $25US per booster and yes, do check how much clearance you have. I've had that problem with Amp B3s.
    Quote Originally Posted by DeeEight
    DeeEight: Can you tell me what your brake boosters measure in height? I will be running a 2.1 tire on the back so the smaller version would probably be OK.
    Thanks...
    the tire clearance is actually identical. The wider one is for cantilever brakes (as they tend to require more room to swing the pads clear when removing the wheel), and as to height, 5.6" overall length, and 5.2" from center of brake bolt slot to top.
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. Shmano and carbon fiber?
    By What&son in forum General Discussion
    Last Post: 06-12-2004, 08:32 PM
  3. Does a brake booster do anything?
    By TheRedMantra in forum General Discussion
    Last Post: 06-04-2004, 08:53 AM
  4. Beginner, want a FS bike, which one?
    By Rich4757 in forum Bike and Frame discussion
    Last Post: 05-31-2004, 07:40 PM
  5. Replies: 4
    Last Post: 02-12-2004, 10:55 AM
