Results 1 to 16 of 16
    New question here. Where can I get this..!? Post mount to IS adapter...?
    I will love to find some of this for a few post mount forks I have..
    Thanks in advance..
    B A N N E D
    http://clee-cycles.co.uk/esite/P1043/product
    Search on ebay for KCNC adapter and you'll find several sellers.
    Quote Originally Posted by cobba View Post
    Product KCNC Disc Brake Adapter Post Fork - IS Caliper
    Thanks senor Cobba always so helpful..
    B A N N E D
    Wow this is awesome, thanks for sharing it..
    Now for another question, do you know of any adapters for the 22mm disc brakes to run more current IS brakes..??
    B A N N E D
    Adapter for 22mm frame mount & IS brake caliper ?
    A2Z AD-PMR adapter: http://www.a2zcomponents.com/02produ...dapter_05.html
    A2Z AD-PMR adapter: www.a2zcomponents.com
    Man Cobba is anything that you don't know about..??
    Awesome find again, now I can put my old Fisher back on the road..
    Cobba where can you get A2Z parts in the US, (they don't have a distribuitor) Ebay..?? )not much there)
    B A N N E D
    B A N N E D
    Quote Originally Posted by patineto View Post
    Plenty of things.
    What's the Fisher, what's the angle on the chainstay/seatstay like and what IS brake caliper do you have?
    With 22mm chainstay mounts it'll depend on what the IS brake caliper is and the angle with the chainstay/seatstay whether the a2z AD-PMR adapter will work.
    It probably won't work if there's an acute angle with the chainstay/seatstay like in this photo.
    With certain IS brake calipers and a greater angle with the chainstay/seatstay like in this it'll work.
    A 'long arm' IS caliper like this or a big bulky IS caliper like this probably won't work with that 22mm adapter either.
    A few threads on IS calipers on PM forks:
    What shimano brake adapter(s) would I use?
    Magura Marta 2006 IS front adapter
    Magura Marta SL adapter help!
    As the IS calipers and the adapters come in different sizes, here's a bit of a guide on fitment and rotor size:
    160mm Post Mounts + 160mm adapter + 160mm IS caliper = 160mm rotor
    160mm Post Mounts + 160mm adapter + 180mm IS caliper = 180mm rotor
    160mm Post Mounts + 160mm adapter + 200mm IS caliper = 200mm rotor
    160mm Post Mounts + 180mm adapter + 160mm IS caliper = 180mm rotor
    160mm Post Mounts + 180mm adapter + 180mm IS caliper = 200mm rotor
    160mm Post Mounts + 180mm adapter + 200mm IS caliper = 220mm rotor
    160mm Post Mounts + 200mm adapter + 160mm IS caliper = 200mm rotor
    160mm Post Mounts + 200mm adapter + 180mm IS caliper = 220mm rotor
    160mm Post Mounts + 200mm adapter + 200mm IS caliper = 240mm rotor
    I take pictures soon, the adapter is for a size 20" gary fisher super caliber and it mounts on the inside of the chainstays, maybe you are right and it will not fit..
    Sorry I took so long..
    B A N N E D
    It might work.
    What brake caliper do you want to use.
    Where can I get this..!? Post mount to IS adapter...?-img_20120801_173848.jpg
    The minimum rotor size with the AD-PMR adapter is 180mm
    It might work.
    Most probably a Hope mono mini, if not a old XTR 96X..
    Thanks again for all the help, I will order one and see what happens..
    Not a problem I'm kind of chubby and I need powerful brakes anyway..
    dirtbag
    Reputation: ranier's Avatar
    Sep 2003
    Good dirt!
    Amolan
    Oct 2013
    hope this helps
    sm-ma-f180 s/p will fit an is caliper to a post mount fork
    Shimano 7 Inch Adapter SM-MA-F180S P Y81737000
  1. Rear post to post mount adapter exist?
    By alfred.fetta in forum Brake Time
    Last Post: 10-20-2013, 05:20 AM
  2. IS to post mount adapter
    By amgine in forum Brake Time
    Last Post: 10-27-2012, 08:24 AM
  3. Replies: 2
    Last Post: 10-20-2012, 07:27 AM
  4. Replies: 7
    Last Post: 01-02-2012, 10:34 AM
  5. Post mount to IS mount adapter...correct me if I'm wrong.
    By ProjectDan35 in forum Shocks and Suspension
    Last Post: 04-22-2011, 08:38 AM
