    Where can I find an I.S. to post brake adaptor for 203mm rotor?
    I have a Fisher Piranha with a fork that has IS mounts. I'm currently running shimano disc brakes and I am going from a 6" rotor to 8" rotor. I need the I.S. to post brake adaptor to make it work(my front caliper accepts either style mount). The local LBS wants to charge $50 for this bracket. Is there anywhere you can get this bracket cheaper? thanks
    AW_
    AW_ is offline
    locked - time out
    Reputation: AW_'s Avatar
    Quote Originally Posted by bahamabluez
    What brake?
    Sounds like any old Avid / Hayes / Shimano adaptor would work... this is usually a $10 part. What kind of bracket are they trying to sell you? Some of the manufacturers are indeed a lot more than Avid adaptors but $50 sounds nuts.
    The brakes are the new Shimano br-m486 that are on several of the Gary Fisher G2 hardtails. I thought my Tora was 74mm post mounts, but it is I.S. mounts.
    Meh.
    Reputation: XSL_WiLL's Avatar
    The Shimano adapters are quite expensive, right around $50.
    You should be able to get away just fine with Hayes adapters.
