Results 1 to 16 of 16
    Reputation: rickcin's Avatar
    When & who to bleed?
    I bought my 29er (GF Cobia) last October and have ridden it for about 2 months and for the entire season this year, probably until the end of November.
    The brakes are the hydraulic Promax Hornet, when should the fluid be changed and is this something I should attempt to do myself or just have the LBS take care of it for me ?
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Are you having problems with the brakes?
    Quote Originally Posted by OO7 View Post
    No, they work well IMO!
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    Then wait until you get problems
    Check out my SportTracks plugins for some training aid software.
    Quote Originally Posted by rickcin View Post
    Wait it out...but consider opening the reservoir and topping up the fluid if it needs it.
    Quote Originally Posted by jeffscott View Post
    Is there information on line how to do it ?
    Google PRomax ????
    007 is offline
    b a n n e d
    Jun 2005
    Then leave em alone.
    Quote Originally Posted by PissedOffCil View Post
    Exactly. Why mess with something that is working well?
    Why bother? If not done properly, "topping up" can do more harm then good (e.g., overfilling the system).
    Google PRomax ????
    Not that easy, I looked on there web site and unable to find some maintenance information.
    These breaks are not all that popular!
    Reputation: Shalom's Avatar
    Nov 2008
    Is this what you are looking for?
    Promax Hornet bleeding
    shalom,
    Thanks so much, I really appreciate it
    Nov 2008
    shalom,
    Happy to be able to help.
    Where can I get a list of the symptoms associated with mus-behaving disk brakes? I was hoping this thread was going to include some symptoms...I'm new to hydraulics so I want to see if I have the symptoms or if something else weird is going on or if the brakes just suck.
    Thanks.
    007 is offline
    b a n n e d
    Jun 2005
    Quote Originally Posted by JustAnotherDude View Post
    Thanks.
    A better approach is to list what's going on and we can be more helpful.
    I spoke with my LBS and the owner said if you are not having any problems at all with your brakes you should still have your fluid changed after 2 seasons. We live in the north wast so the winter is about 5 months of down time.
    Yeah, I agree... Just like your vehicles brake fluid.... every two years. Your brakes will still work if you dont but you may experience increased levels of brake fade. It's not hard to do yourself just a little messy and time consuming. You need a kit to do it which will probably consist of generic plastic syringes with tubing and adapters to screw into your caliper and master cylinder.
    Killing it with close inspection.
  1. Replies: 0
    Last Post: 05-31-2011, 08:28 AM
  2. Manitou: To bleed or not to bleed...
    By SPIDERS in forum Arizona
    Last Post: 11-05-2010, 04:12 PM
  3. Anyone bleed Juicy 7's without the Avid Bleed Kit?
    By IRONMAN1518 in forum Brake Time
    Last Post: 02-01-2009, 08:36 PM
  4. Replies: 5
    Last Post: 06-20-2008, 05:10 PM
  5. Tricky Hayes Bleed Mystery ... won't "hold" a bleed
    By KobaltBlau in forum Brake Time
    Last Post: 04-20-2007, 02:59 PM
