Results 1 to 10 of 10
    When torquing down rotor bolts do you use…
    Grease?
    Antiseize?
    Nothing?
    If it matters it will be rotors from BB7s with standard hardware.
    Blue loctite...or other medium strength thread locker.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Like he said. And do it in a star pattern to prevent warpage.
    I like turtles
    Quote Originally Posted by gmcttr
    Ditto.
    Can Tree Member
    Reputation: Dad Man Walking's Avatar
    Sep 2004
    I was flummoxed by this very same question several years back when putting rotors onto my new Chris King wheelset. In a moment of desperation that no doubt impaired my judgment, I used a shmear of teflon pipe dope. Worked great, I've not had to touch the rotors since then.
    And I dread the day when I have to replace the rotors...cleaning that stuff out will be a PITA. (Unless I just use more pipe dope.)
    Dad is sad.
    Very, very sad.
    He had a bad day.
    What a day Dad had!
    Jul 2003
    New out of the box...
    rotor bolts usually come with a smear of blue thread locker already applied. Just use that if it's present. If they are used bolts then the factory stuff may not be there, just use a drop of blue loctite on each bolt and you'll be fine.
    Good Dirt
    Could the goop you use affect brake noise?
    Quote Originally Posted by smilinsteve
    Never say never, but I sincerely doubt it.
    thanks for the replies guys...
    The product photo of the brake hardware shows a blue large "dot" on the threads. So if I see that on my hardware I am good to go? And yup I will tighten in a star pattern and gradually.
    Thanks Again!
    bi-winning
    Reputation: rkj__'s Avatar
    Quote Originally Posted by Nickbee
    Yup! Good to go.
