Results 1 to 17 of 17
    Reputation: Thatshowiroll's Avatar
    Jan 2009
    What's wrong with my XT hydros?
    Brand-new, installed and bled by me. (Which may be the problem.)
    My front brake, at the start of a ride, you can pull the lever all the way to the bar.
    Pump it 20 times and it starts working.
    I store my bike hung up by the front wheel if that helps.
    Reputation: mitzikatzi's Avatar
    That sounds like air in the system. Rebleed them.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    El Gato Malo
    ^^^This
    Jan 2009
    Thanks. I'll just bring it to the shop because I suck at doing brake bleeds.
    El Gato Malo
    What method were you using, the Shimano approved or the syringe?
    Jan 2013
    Quote Originally Posted by mitzikatzi View Post
    Guys, how much does the shop usually charge to bleed both brakes?
    El Gato Malo
    Had Avids done years ago and was charged $30 for one. Depends on the shop.
    Jan 2009
    Quote Originally Posted by Wishful Tomcat View Post
    Didn't know there was a Shimano method.
    I'm using the syringe method. Screw the syringe into the reservoir, undo the nut at the nipple on the caliper, and inject the fluid until theres a continuous flow. Close the nipple-nut.
    El Gato Malo
    Just wondering, the Shimano way is a gravity bleed towards the caliper.
    Apr 2005
    This is the Shimano method (PDF):
    http://www.shimano.com/media/techdoc...9830648123.PDF
    These are the instructions from Park Tool on how to bleed Shimano brakes:
    Park Tool Co. » ParkTool Blog » Shimano® Hydraulic Brake Service and Adjustment
    I haven't attempted either method yet. I'm putting it off until winter. I would like to know which one works best.
    Justin
    Salt Lake City
    2012 Specialized Stumpjumper FSR Comp 29
    2006 Specialized Allez Expert Double
    El Gato Malo
    Super easy using syringes, even with screw-ups, takes about 15 minutes.
    Jan 2009
    My xt brakes are new style 2012. DO NOT use these methods with new style shimano brakes. You are not supposed to remove the reservoir cap on the new style brakes, or you ruin the diaphragm. You only remove the one screw and screw in the syringe there. I learned this the hard way. I ruined my left hand lever by using this exact pdf off of the internet.
    Quote Originally Posted by authalic View Post
    Reputation: heavyd66's Avatar
    Mar 2012
    so how do you bleed the 2012 xt's then?
    Jul 2013
    The way I bleed them is take off the bleed screw cap on top of the lever, screw the yellow shimano funnel in, connect a hose and syringe at the caliper, open the bleed screw at the caliper and push the fluid from the caliper until the funnel fills up with old fluid, flick the lines to get air out, plug the funnel and take out of bleed hole, close the caliper screw, put the plug back in the lever and screw tight, Done.
    This seems to be the best method I have found so far, I tried bleeding them from the lever down to the caliper but I could not get a good feel out of them, bleed ing from the caliper and pushing the fluid up through the lines seems to get the air out a lot better.
    Edit: If you do not have the Shimano funnel, my lbs owner gave me one for free one visit, I believe you can just use a largish syringe with no plunger it it so it acts like a funnel to hold the brake fluid.
    Mar 2012
    Get the funnel. The newer SLX/XT/XTRs are so easy and you'll save a boatload of money in just one bleed. Don't forget the yellow bleed block.
    Jan 2009
    Quote Originally Posted by subsist View Post
    I was doing your same method, but in reverse. Next time, I'll try from the caliper and up.
    Jan 2009
    I finally got around to trying this method. Injecting the oil from the caliper was a huge success. Thanks.
  1. hydros from ebay
    By Markleo in forum Brake Time
    Last Post: 03-28-2013, 01:24 PM
  2. mechanical VS hydros
    By nvphatty in forum Fat bikes
    Last Post: 04-12-2012, 10:54 AM
  3. Replies: 9
    Last Post: 09-08-2011, 03:50 AM
  4. M575 Hydros
    By applehead110 in forum Shimano
    Last Post: 06-09-2011, 04:53 AM
  5. BB7s vs. Hydros?
    By myitch in forum Brake Time
    Last Post: 01-31-2011, 10:50 AM
