Results 1 to 9 of 9
    whats with the Avid Polygon rotor?
    ok so whats the deal with them cause i finally figured out that my "unknown" front rotor is an avid polygon.
    any info?
    trail addict
    Reputation: Uncle Six Pack's Avatar
    Quote Originally Posted by AlexJK
    any info?
    ummmm, what do you want to know? It is a rotor, it does what brake rotors do...
    You better just go ahead and drop that seatpost down to the reflector... the trail gets pretty rough down there.
    Jul 2003
    any info?
    Actually they are Avid "Roundagon" rotors. That's whe they call em anyway. They are Avids low end rotor, they're serviceable and work fine. But are less than stellar when it comes to heat disapation when compared to other Avid rotors like the G2 and G3 clean sweeps. That and they're a bit heavier as well. Not much else to say about them. As Uncle noted, they're brake rotors, they do what brake rotors do.
    Good Dirt
    Reputation: vk45de's Avatar
    Jan 2009
    search "roundagon" you'll find the kind of read you want. to ask this kind of question, you must be bored anyways.
    but it's not a roundagon... and i had some major problems up front with a clean sweep g2,
    lbs swapped it out for this and all is well
    i just wanna know production years, what brake it came with, etc.
    i haven't been able to find much on it
    Meh.
    Reputation: XSL_WiLL's Avatar
    Roundagons are not the same as Polygons. Polygons came with 2005(?) Avid Juicy brakes.
    Polygons came in around the same weight as the original Cleansweep rotors.
    Polygon
    Roundagon
    yep, thats the one, thanks!
    FPT
    so was it the roundagon or the polygon which quite a few folks blamed for the famous Avid turkey warble?
    i dunno but come to think of it i did get that turkey noise a few times with the clean sweep and my BB5s
Hot Deals
Contests
Latest Mountain Bike Articles
