Results 1 to 34 of 34
    I hate that name.
    Reputation: blunderbuss's Avatar
    What are you cleaning rotors with?
    Man, I'm stumped. I've always used rubbing alcohol, at home and at work. I'm looking for something better. I'm not positive, but I think I may have contaminated my rotors (Shimano Icetech XT level) with something that the alcohol can't get rid of. My brakes lost the grabby feeling (current gen XT), so I cleaned rotors and pads with alcohol, with a bit o' sanding on the pads, no change in feel. So I replaced the pads (tried resin this time) and cleaned the rotors again, success for a couple rides, then back to feeling numb. That's where I am now. I've got 10 year old BB7s with worn pads that feel more responsive. Any ideas?
    Worked at Trek/Fisher dealer 2008-2013. Only a little biased.
    Brake cleaner. Your pads are also likely toast, if you didn't get the contaminant off the rotor the first time.
    I hate that name.
    Are we talking automotive grade?
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    【ツ】 eDub 【ツ】
    You can use automotive stuff if you want, though White Lightning's Clean Streak is far less caustic to you.
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Re: What are you cleaning rotors with?
    I say regular alc. does the trick. Those others are dirtier and toxic. Those are made to go on your car rotors which you will rarely go anywhere near with face or hands, maybe when you wash your car and get down there to clean the wheels.
    On your bike, your face and hands are routinely close to your rotors, removing wheels, throwing your bike on your roof rack, etc. I wouldn't use any of those car cleaners for that reason.
    Clearly, the alcohol didn't work...
    Reputation: millertm's Avatar
    I use automotive grade disc brake cleaner. For a few bucks it lasts for a while. Just spray it on a rag and use the rag (clean rag) to clean your rotors. It will remove paint and eat tires.
    Mark
    2012 XXL Carve Expert
    The rubbing alcohol you buy at the shops is often around 70%. It doesn't work nearly as well as 90% or higher isopropyl alcohol. That works great. You should be able to get some at Walmart for $3, and some drug stores sell it as well.
    Never enough time to ride
    Reputation: squish's Avatar
    Another vote for Clean Streak, I have been using it effectively in the shop for a while now. Does not seem to leave any residue behind.
    happy trails...
    squish
    Get out and ride!
    nvphatty
    Guest
    clean streak, 90% rubbing alcohol and brake cleaner all work wonders for removing residues etc that find their way onto rotor surfaces.
    Dbl check the calipers for fluid leaks near the pistons, bleed screw port and brake line fittings for the slightest seeping fluid.
    Quote Originally Posted by nvphatty View Post
    I second that, it is amazing how little brake fluid can make you brakes almost useless.
    Jun 2012
    I use isopropyl alcohol(90%)
    Works very well, after I landed sand the brake pads and do a new pad brake in. Never gives me any issues.
    nvphatty
    Guest
    Quote Originally Posted by Learux View Post
    be careful with sandpaper / emory cloth as they contain adhesives that transfer to said surface.
    Jun 2012
    You sure about that? I just take the glaze of the pads, clean the rotors with 90% IPA, do a brake in and all is well.
    I don't see how adhesives from paper will ever transfer to pads.
    Maybe after sanding clean pads with 90% IPA to remove adhesives?
    Off the saddle
    Reputation: jizzim's Avatar
    I've used mass airflow sensor cleaner. It's dries pretty quickly and doesn't leave any residue behind due to the nature of the part it's suppose to technically clean.
    Killer b.
    Reputation: The Understater's Avatar
    Mud. Well, moist dirt really. Find some fine grained dirt, wet it if you have to, and rub it all over your rotors before doing some hard stops... Repeat. This has worked for me any and every time I've had contaminated rotors. And not just brake fluid either. Sometimes being on the hitch rack in the rain will get oil and road grime onto the rotors.
    I've heard cement dust works quite well too, but haven't tried it.
    Posting on the basis that ignorance shared is ignorance doubled.
    ^^ +1 and its free!
    nvphatty
    Guest
    yessir I am. sandpaper/emory cloth are both comprised of tiny bits of sand or emory glued together to produce the products
    Pure Acetone is my cleaner of choice.
    Cheap, easily obtained, and has many uses.
    Dec 2005
    wd40 and duct tape
    I kid, ISO alcohol and or brake cleaner work well.
    nvphatty
    Guest
    Quote Originally Posted by rideitall View Post
    wd40 and duct tape
    perhaps a propane torch is in order.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    this myth keeps coming up..
    the "adhesives" you speak of are dry particle... no sticky, tacky or transferable properties remain to them once they are dried in the factory. The metal shavings of the disc or pad from sanding is more difficult to remove do to static energy than anything from the sand paper. wipe off with a rag or water and they are gone. Concrete is an "adhesive" when wet.. not so much when dry...
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Not sure if it has been said, but I use Denatured Alcohol. It's an excellent metal cleaner, evaporates fast and leaves no residue at all.
    Nov 2007
    Dishwashing liquid
    Sent from my GT-N7105 using Tapatalk 2
    nvphatty
    Guest
    Quote Originally Posted by thomllama View Post
    and will keep coming up as FACT thank you. I've stated it before and will again when necessary.
    Oct 2007
    better call every plumber in the world and tell them their sweated pipes are no good because the adhesive from the from the sand paper has transferred to the pipe...
    oh.. and all the companies that make the rotors.. as the sand paper they use to polish the stainless steel is cover in it also... oh.. and the guy who welded your frame as it' has contaminated the welds...
    it's not rubber cement.. it's a baked, hardened resin.. again, no adhesive properties remain after backing... nothing to transfer... they haven't use hide type glues since like the 40's and even that washes off with water or any other liquid so there is zero issues with using sand paper
    Jan 2014
    Hi
    Did ya get ya Xt ice tech rotors/brakes to work???????!
    Yesterday I cleaned my rotors with CRC break cleaner
    Today they don't feel no good
    Today was a sad day for me
    Reputation: mitzikatzi's Avatar
    Quote Originally Posted by Bay1 View Post
    Hi
    If you clean your brakes with brake cleaner. You then need to rebed in the brakes for best performance.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    Jan 2014
    Rebed breaks?
    Just short sharp breaking?
    Oct 2007
    go read the manual as each type has slightly diff requirements... (can get 99% of them online from manufacturer's sites) but basically most want you to get to a decent speed and do a quick slow down without actually locking up or coming to a full stop,.. usually do it a few dozen times... again some have slight variations they require depending on pad and rotor material types.
    Workin for the weekend!
    Reputation: -Todd-'s Avatar
    An open flame is the best way to recondition oily pads. If you glaze then, then sand them, otherwise your bets bet is burning the contamination out. Solvent will only remove the stuff on the surface...
    Try it...
    Todd
    Also do this on the road so u can do it smoothly.
    Rebed breaks?
    Brakes
  1. Replies: 14
    Last Post: 04-24-2017, 12:30 PM
  2. Ice Tech rotors vs HS1 rotors
    By shoresnapper in forum Brake Time
    Last Post: 07-27-2014, 12:10 PM
  3. VPP cleaning.
    By Simpledesign in forum Santa Cruz
    Last Post: 04-07-2013, 08:10 PM
  4. Replies: 2
    Last Post: 03-26-2013, 05:31 AM
  5. Cleaning rotors
    By Surfpoodi in forum Brake Time
    Last Post: 11-20-2012, 03:55 PM
Members who have read this thread: 15
