Results 1 to 10 of 10
    Programmer
    Nov 2006
    What size Hope caliper adapter do I need?
    Hey there- Doing some upgrades, but plan to continue using my Hope Mono Mini hydro disc brakes (2007). Anyway, my new fork is the Fox Fit RLC 32 100mm post mount, and my frame is the Vassago ChubaChabra. I'm new to caliper adapters, what do I need to be aware of, how do I find the right one?
    ... sorry for the noobness
    Programmer
    Nov 2006
    IS to Post adapter...
    Hope Mount Adaptor Front IS to Post +20mm | Buy Online | ChainReactionCycles.com
    This looks like it might work for the front. I definitely need:
    Front IS to Post (+20mm increase)
    The +20mm increase means I need to purchase a new front disc... 20mm larger?
    Reputation: shiggy's Avatar
    Dec 1998
    We need a pic of your calipers. IIRC there were IS and post mount versions of the brake
    mtbtires.com
    Programmer
    Nov 2006
    IS mount
    Yep, IS mount.
    Attached Thumbnails Attached Thumbnails What size Hope caliper adapter do I need?-img_5631_104.jpg
    Programmer
    Nov 2006
    So if I use the Hope is to post front adapter I posted above, I will need to run a larger rotor? From 160mm to 183mm?
    B A N N E D
    With the +20mm adapter you'll need to use a 180mm rotor.
    Programmer
    Nov 2006
    Got it! Thanks!
    Coffee Drinker
    Reputation: Taildragger's Avatar
    Mar 2005
    Hope rotor question, do 183mm rotors interchange with 180mm rotors? 203mm with 200mm?
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Quote Originally Posted by Taildragger View Post
    No they do not.
    Programmer
    Nov 2006
    good to know...
  1. Shimano xtr caliper with hope mount adapter?
    By Angus Crake in forum Brake Time
    Last Post: 07-11-2009, 08:34 AM
  2. Hope Mini caliper bolt size
    By mtberfrombothell in forum Brake Time
    Last Post: 12-27-2007, 12:12 PM
  3. Adapter XT caliper hope rotor
    By sxotty in forum Brake Time
    Last Post: 09-29-2007, 03:49 PM
  4. Replies: 9
    Last Post: 12-17-2004, 08:45 AM
  5. Hope M4 caliper Size Question ???
    By Atomik Carbon in forum Brake Time
    Last Post: 05-03-2004, 04:23 PM
