Results 1 to 3 of 3
    Reputation: pherret's Avatar
    What size disk brakes???
    I am looking at getting a set of avid mechanicals for my HT and Full sus. I have a jamis dakar pro and komodo. I weigh in at 260lbs. Would the 7 or 8 in be better than the 6 for my weight. Most of my riding is XC. Also my HT has the 22mm frame mounts. Has anyone had a problem running the adapter on their frame?
    The wheelset I am getting is the sun rhyno lite xt hub wheelset from pricepoint. Anyone have problems with pricepoints wheelsets?
    Thanks for the help
    Pherret
    Big == better
    Quote Originally Posted by pherret
    Thanks for the help
    Pherret
    I can't speak to the frame compatibility, but for brakes I would go with 200mm front, 185 rear at least, and possibly 200 rear. I go about 230 and I run the 200/185 combo, and it is great. With the bigger discs, since you don't have to grip so hard, it's easier to modulate. I have bought one set of wheels from Pricepoint, and they are fine.
    El K.
    Thanks for the help
    Pherret
    I am 230 and I run a 145/165 Hydro Hope Minis. I love these brakes. For Avids I would Go 165/185. If you do not have a 20mm axle on the front you can have to much brake. Most fork Manufactures void the warrenty for anything over 185mm if the axle is QR. Good wheel choice. The Rhyno Lite is a good big guy rim. Check with Sun and Shimano to make sure they will warrenty items bought from Price Point. Some Companies won't. Good luck with the adapter. I have never used one.
  1. Ahoy! V-brake holdouts!
    By Padre in forum Singlespeed
    Last Post: 03-23-2004, 10:06 AM
  2. Mech Disk Brakes...Avid or Hayes???
    By BlurryTrees in forum Downhill - Freeride
    Last Post: 03-20-2004, 10:51 AM
  3. burner ready for canti & disk brakes?
    By oxygenrace in forum Turner
    Last Post: 03-04-2004, 08:41 PM
  4. Replies: 7
    Last Post: 03-01-2004, 06:45 AM
  5. Replies: 17
    Last Post: 02-06-2004, 07:05 AM
