    May 2013
    What rotors to use with bb7?
    What rotors are you guys using with your bb7? I only have disk on front, 160mm. What are the thoughts on Avid HS1.
    Thanks.
    WillWorkForTrail
    Jun 2012
    Any rotor you have the right size mount adaptor for should work. I've used the Clean Sweep rotors with mine, as well as Ashima Airotors.
    Reputation: ms6073's Avatar
    I have used BB7 SL's with Ashima Ai2 rotors and semi-metallic pads for cyclocross which I thought offered pretty good braking but on longer descents or in the wet the pads produced a squeal.
    Reputation: Just1Gear's Avatar
    Jan 2011
    I used Gatorbrake rotors with good success with BB5's and BB7's, and now I'm still using them with Formula brakes.
  1. Replies: 14
    Last Post: 04-24-2017, 12:30 PM
  2. Ice Tech rotors vs HS1 rotors
    By shoresnapper in forum Brake Time
    Last Post: 07-27-2014, 12:10 PM
  3. Alligator rotors just as good as Avid rotors?
    By Lindahl in forum Brake Time
    Last Post: 09-19-2013, 02:08 PM
  4. Replies: 2
    Last Post: 03-26-2013, 05:31 AM
  5. What Rotors are you using?
    By Triaxtremec in forum 29er Bikes
    Last Post: 07-03-2011, 06:32 AM
