Results 1 to 7 of 7
    What is purpose of Red torx bolt Avid juicy Ultimates caliper?
    What is that purpose of that and also what size torx bolt is that because I am using an allen wrench to turn it because I was tring to take it out to push the piston out as I dont have compressed air but it just pushes in and cant back it out. Any help is appreciated...
    Well I figured it out... It goes in toward rotor, Got it all out and it looks like there are 2 washers on the red torx screw. A big one and small one(I am not sure if there is a small one)? The big one is fine but small one is gone. Do we think that is why the piston got stuck? Also can I pick that washer up at a Home depot as I dont want to have to wait to order it from local shop?
    Reputation: scooter916's Avatar
    rule #1, if you don't know what it does don't mess with it.
    Quote Originally Posted by thefuzzbl
    aluminium has a tendency to fail when you need it most. i.e. you end up with a bad day.
    Reputation: bvibert's Avatar
    Mar 2006
    Have you looked at the service manual? Seems like a good place to start.
    http://www.sram.com/en/service/avid/tech_manuals.php
    Looking at it quickly I don't see anything about washers in there. There is an o-ring though.
    I couldnt find the technical manual. Thanks
    In step 12 what and where are the inboard and outboard quad seal o-rings?
    Well got it done, first bleed took 45 mins and once I was use to it second took about 15... So cool when you learn something. Now I feel bad I spent 30 bucks to have lbs do it the first time...
