Results 1 to 10 of 10
    What pads are these?
    Bit of a longshor but here goes. My Tektro Dracos make a warbling type noise mostly in the rear brake. I've realigned them and it still does it. I'm wondering if it's the pads. The pad surface has shiny flecks in it so does that mean they are sintered pads?
    I've googled the number but all I get is car brake pads. The Tektro site states that they are semi-metallic I'd like confirmation.
    Reputation: Shalom's Avatar
    Nov 2008
    Those pads look to be well past their use by date. Best bet is to take them in to your LBS and get them to find out what they are. At the least, buy one set from them to replace before buying more online. Otherwise, support your LBS.
    I've only had the bike a few weeks. Prior to that, the bike was on the shop floor for a while - that is, they have a lot of pad left.
    By chance I found some isopropyl wipes in my shed which I used to clean the pads and rotors. They still howled badly so I followed the bedding instructions from http://steveukmtb.wordpress.com/basi...otor-cleaning/ and lo they are now silent and stop on a dime.
    It's early days but fingers crossed!
    Update: the noise came back but I think I wasn't getting the rotors hot enough. I'm going to go out for a ride next weekend and get some longer descents in to really heat them up.
    Those look like sintered pads.
    They do like to get hot before they get quiet on some bikes. If it's humid where you live, then they will probably do it all the time until you heat them up.
    I like them on the front, but not the back. I use a lot less pressure on my rear brake, so the don't heat fast. That howl is annoying to me.
    Lead by my Lefty............... right down the trail, no brakes.
    Quote Originally Posted by Shalom View Post
    Can you explain what you mean by "look to be past their used by date"?
    Reason I ask is mine look just like that.
    Quote Originally Posted by Dalistro View Post
    Those pads look normal. The pad life is determined by the remaining thickness.
    Nov 2008
    Quote Originally Posted by gmcttr View Post
    Correct. However, to me (I could be losing a bit due to the photo), those pads look somewhat glazed. And that does affect their performance.
    There's definitely metal flakes in the pads but I gather sintered pads always have a copper back plate to transfer heat.
    Anyway I went out for a ride today and got some good descents in. They were noisy for a minute or two but then threagent silent for the rest of ride.
  1. Sixsixone evo d3o pads or dainese 3X pads
    By aldeezy in forum Apparel and Protection
    Last Post: 01-29-2011, 06:51 PM
  2. volleyball pads as knee pads?
    By crash821 in forum General Discussion
    Last Post: 02-12-2009, 07:37 PM
  3. Replies: 36
    Last Post: 03-28-2008, 07:29 AM
  4. Avid bb7 pads - anybody used the ritchey pads?
    By asyluminc in forum Ritchey Design
    Last Post: 02-02-2008, 06:47 PM
  5. XT pads not touching rotors after resetting the pads, plz help.
    By big_mountain_biker in forum Brake Time
    Last Post: 01-07-2008, 02:26 PM
