Results 1 to 35 of 35
    Sep 2004
    What a drag....help me on my HayesHayes HFX-9 XC
    Drag drag drag. I have tried it all except bleeding, the rotors were never pumped out and dont behave as if they need to be bled. All they do is drag, sap the energy right out of my poor legs. I have adjusted caliper location many times, I have pressed the pads back in and relied on the auto-adjust and no help. I get them a bit better but they still drag. Any ideas?
    Reputation: skywaybuzz's Avatar
    Are the pads new? Sometimes they need to wear in thinner. pull the pads and push carefully the pistons in so they are flush with the caliper (patience required) this should set them. Somtimes it helps to not use them unflat washers under the caliper bolts to get the final seating of the caliper straight.
    Reputation: Knucklehead's Avatar
    Quote Originally Posted by skywaybuzz
    Yup.
    With Hayes brakes, there is a little play when you mount them to the frame so you can position them. Tried loosening them up and moving them over/reposition them? This has fixed every single drag problem I've had on my bikes with Hayes disks (4 bikes.. HFX MAG's and Nine's).
    Also, if it's just a matter of pushing the calipers in, do you have the little plastic shim dealy that came with the new brakes (keeps the caliper open during shipping, etc.) I kept mine, and shove it in between the calipers to spread them to an almost perfect fit. Although I always have a slight bit of drag for thr first one or two rides until new pads wear in.
    Sep 2004
    The pads are not new, the bike has been plenty used...I have tried every method of adjusting except bleeding and I think that is an extreme. I have had no problems on my hardtail with Avid BB mechanical discs getting perfect operation, not so with these Hayes brakes, no matter what they drag. I have pressed open the calipers, with the pads in, as far as I can, I remount the wheel, give a spin and all is fine, then when I grab a handful of brake lever and squeeze, the self adjust mechanism puts them right back on the disc...dragging away. Its almost as if internally the self adjust is set wrong.
    stay thirsty, my friends
    Reputation: LBmtb's Avatar
    I have the same drag issue . . . I'll try some of the suggestions in this thread in a few days when the schedule clears up.
    bike moron
    Reputation: windidiot's Avatar
    If your levers feel solid (not spongy/mushy which would indicate air & need for bleed) Its possible that ther'e's too much fluid in the system. Had that problem with a new bike once. It was pretty obvious when I went to pick it up, they replaced the fluid and I figured that was all set. I kept having the same kind of problems until I took the bike to a different shop, which diagnosed the problem: still too much fluid. The guy told me what to look for when filling, but since I don't do that myself I've forgotten...sorry about that, but I guess the message is that if there's just a little too much it may not be any easy problem to diagnose.
    I've found that Hayes can be finickey on certain bikes. On my Stumpjumper I often need to fiddle with caliper alignment, bend a rotor a bit, etc. Much less so on any of the other bikes.
    Sep 2004
    How much fluid did you let out....I tried this very quickly letting out a bit, and making sure not to get air in the system and this did nothing?
    bike moron
    Quote Originally Posted by Brodirt
    The second LBS guy did it, so I don't really know; he did tell me what to look for but I'm really fuzzy on that since it was over a year ago...sorry....but if that sounds like something you want to pursue my advice would be to start at a pretty low fluid level & experiment...you can always add more.
    I tried pushing in the piston and it was ok until I squeezed the lever. It rubs on the inside pad which leads me to my next attempt . . . shims.
    What size shim do I need? Brakes came with the bike and so I didnt get the shims that hayes supplies with them.
    Hayes don't really use shims, If it rubs on the inside pad move the caliper in, if it still rubs the inside pad check that your pistons are about the same extended, if the inside piston is out more so than the outside piston push it way back in with the pads removed. Then remount the caliper semi loose and pull lever slow while holding the disc up against the piston you dont want to move as much as before. This will help get the pistons set right.
    Only thing to shim is the adapter out some with thin washers or the super thin shims that come with Magura or Hopes, Shimano. I've never had to do this thou. I have round filed the holes in the caliper to allow extra clearance.
    I pushed the pistons back in till they were flush and when I got everything put back together the wheel turned fine with no drag. After I squeezed the lever though it rubbed again. Looked at the hayes manual and looks like shims will be the next thing to try for me.
    Sep 2004
    My problem is even stranger still....I can loosen up the mounting/adjustment screws on the calipers and the wheel will turn truly and freely with no rub. I tighten up the caliper and whammo! the rub returns.
    Are you still using the washers under the bolts?
    Sep 2004
    Yes....your reaction makes me say that I will take them out and give it a try, seems too obvious though....hey ya never know.
    Reputation: 006_007's Avatar
    In one of your earlier posts you mention that they are well used, I had a well used (4 years) set of hayes that I could not get the drag out until a shop mechanic suggested I clean/lube the pistons in the caliper. Simply pulled the pads out, pumped out the pistons a bit (not so much that they popped out) cleaned then lubed with......WINDOW cleaner.
    Voila pistons retract all the way now.
    Just my $.02
    TJ
    Sep 2004
    my reference to "well used" was just in regard to the question of breaking in the pads....The bike and brakes are only 6 months old, they have gotten plenty of use in that time. Thats all.
    So anybody know what size shims I need for the hayes nines?
    Trail Rider
    Reputation: Quattro's Avatar
    Which end of the bike do you have the problem? Is it a FS or HT?
    Reputation: Dougal's Avatar
    Hayes 101
    First tip.
    Take the wheel out, pump the lever a few times to get the pads moving. Push the pistons/pads in and out several times to make sure they move freely.
    Then replace the wheel, pump the lever till the pads grip and realign the caliper so the rotor runs clean between the pads.
    Shims.
    Throw that crap away. Hayes do not need shims of any description. If you can't get them to line up then something is badly wrong with you or your bike. Hayes hydraulic pistons self align to the rotor, they do not need angled or pissed around with.
    If you need any more advice on how to setup hayes (incl bleeding) then it's on my site (dougal.co.nz).
    Owner of www.shockcraft.co.nz and NZ Manitou Agent.
    www.dougal.co.nz Suspension setup & tuning.
    SPV Devolve
    Sep 2004
    Been there....done that....and yes I know what I am doing.
    I tried this technique described in one of my repair books for hayes brakes and it worked so far. (havent gotten to a trail, but pumped the lever and still didn't rub)
    Loosen the two upper bolts
    pull the brake lever while retightening the bolts
    should cause the brake unit to center perfectly with respect to the disk position. I'ma take it out and ride it in a few hours, I'll let you know if it worked.
    Then it's bleed time.
    If there's any air in the system, the pistons won't retract properly.
    SPV Devolve
    Quote Originally Posted by LBguy
    Still dragged a bit. It was better today but the problem didn't disappear.
    Tightening the bolt can cause the caliper to twist.
    Sometimes, when you tighten a bolt, the caliper will move. The friction between the washer and the caliper causes the washer to grab the caliper. Watch carefully when you tighten to make sure the caliper doesn't move.
    Look thru the caliper with a piece of white paper behind it, you can see where it rubs when you spin the wheel. Then just losen the bolts and move the caliper so it doesn't rub anymore. That business of clamping the rotor and tightening the caliper doesn't always work so well. I sometimes shine a light behind thru the caliper to see if its centered.
    Have you trued your rotors up?
    SPV Devolve
    shut up and pedal
    If the piston will not retract on it's own, it's likely do to dirt or grunge. As other posts have suggested overextend the piston and try cleaning it with alcohol. When I replace pads once a year I disassemble the caliper and clean everything. The groove that the o-ring fits in is always packed with dirt. The o-ring is what retracts the piston. There are no springs or mechanism that retracts the piston.
    Ride
    Quote Originally Posted by Ridethebike
    Ride
    There are two things which retract the pistons. The first one is the rolling action of the square seals. The second is the master cylinder piston retracting (it is sprung) and sucking the fluid back with it. For your pistons to retract requires both these things to be working.
    If you brake isn't bled properly, the air bubbles will just expand and contract instead of letting the fluid help suck the pistons back.
    SPV Devolve
    shut up and pedal
    Yes, D. I agree with bleeding, easy enough to try and see if that works.
    Most bike riders are fearful of the bleeding process or worst.. overhaul a caliper.
    Reputation: disco's Avatar
    bump this topic!
    I have a set of HFX 9's on a used Liquid that I bought last year. Rear brake is dragging so I bring it to the shop and he bleeds it. It's better but still doesn't fix it completely. After reading this thread I got inspired and took the caliper off to have a closer look. After taking the brake pads off I notice one pistion will not push out. After trying a few times to pump them out, spray with alcohol and push back in, I can get the outside one to work. The inside one will only push out a little bit.
    I'm trying to think of a way to work it loose without taking apart the calipers completely, rebleeding, or possilbly damaging them by pushing on the pins. I'm thinking of putting the brake pad back on the outside one, holding it over the disc tight to the outside pad and then pumping the brake to try and get the inside piston to push out completely. Then try and spray it down/clean it, and work them both in and out a few times and remount them. Think this will work or is there a better way? I'm a total noob when it comes to disc brakes.
    thanks in advance for any help
    Quote Originally Posted by disco
    Car parts shops sell stuff called "rubber grease". It's a grease especially formulated for use on brake seals and pistons. Smearing that on the exposed piston and working them in and out will fix any sticking problem.
    SPV Devolve
    Quote Originally Posted by Dougal
    had a closer look at at them last night, the pistons seem to be deteriorating near the edges, crumbling apart. The bike is used, and I've had it for a year but not ridden much due to knee surgery. Don't know if the previous owner damaged them by digging at them with some tool trying to push them back in or something but the one piston is pretty stuck. Very hard to get it to push out and hard to force back in.
    What about WD40? will that eat the seals?
    By the time it takes to get new pistons and re-build is it worth it for these things to potentially have more problems???
    For $99 on Pricepoint I might just wave in a new one.
    You don't want to spend ~$5 on some brake lube first?
    One I have is called "Sylglyde" (sp?) and you can find this or something similar at most car parts places.
    Quote Originally Posted by fsrxc
    thanks, I'll try it this w/e, supposed to rain all w/e might as well get wrenching
    Don't worry about crumbling at the edges, they pistons are quite brittle and it doesn't take much to chip the edges. It doesn't sound like you need new pistons at this stage.
    The best way to pop loose a stuck piston is to pull out the pad on the stuck side and use a tyre lever (or similar tool) to wedge the free piston back while your assistant squeezes the lever.
    I wouldn't use WD40, a little brake (DOT 3,4,5.1) fluid would be better.
    SPV Devolve
  1. Enduro Owners Hayes HFX 9 or Juicy 7's?
    By CCRiderKY in forum Specialized
    Last Post: 07-20-2004, 01:27 AM
  2. Replies: 3
    Last Post: 07-19-2004, 05:13 PM
  3. Hayes HFX 9
    By opticals in forum Brake Time
    Last Post: 06-25-2004, 03:55 AM
  4. Local DH'r kicks ass in the XC at Sea Otter
    By Slayer77 in forum Downhill - Freeride
    Last Post: 04-26-2004, 12:56 PM
  5. Hayes HFX 9 - HD any good?
    By freeriderB in forum Downhill - Freeride
    Last Post: 03-31-2004, 11:12 AM
