Results 1 to 6 of 6
    Caution;  Merge;  Workers Ahead! What does this feel mean?
    Well when I'm riding my front brake feels like its vibrating really fast. So when you put pressure on it, it vibrates. Can you tell me what this means. thanks
    I think its means new brake pads, but i'm not sure.
    Quote Originally Posted by ilikemybike011
    You don't like a fork because it's popular? That's the most retarded reason I have ever heard of.
    Also, your rotor could be warped/bent, or your pads and/or rotor could be contaminated.
    contaminated??
    Quote Originally Posted by idaho biker 90
    contaminated??
    Yeah, some oil, like finger grease, could have gotten on them. You can clean with some rubbing alcohol. When you take the pads out to clean w/ the alcohol, you can check to see if they are worn. The problem is most likely a bent rotor, or as you said, pads in need of replacing.
    Ride Responsibly
    Reputation: LWright's Avatar
    loose bolts maybe?
    its not the bent rotor cause i do a pretty good job on keeping up with that. I'll check the finger grease and the amount of brake left. How much should be left. ??
