Results 1 to 8 of 8
    Expert Noob
    Reputation: LandoCommando's Avatar
    What does a bubble feel like in your line?
    What does a bubble in you brake line feel like?
    Is it squishy with no real response?
    Reputation: Wombat's Avatar
    If you have air in your lines you'll find that the lever moves to (or closer to) the handlebars with little effect on the brakes. If you pump the lever a few time you will compress the air and it will probably engage further from the bars, until next time when you have to repeat the process.
    Tim
    Reputation: vk45de's Avatar
    it feels like my lever's not attached to anything
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Bleed the brake and see if you get a bubble or more if you do you know what a bubble feels like if none then you dont have a bubble in the line.
    Formotion Products
    http://www.formot
    already did quite some time ago. just recalling the feeling for OP
    Lack of power, squishy when the pads hit the rotor, longer lever throw, etc.
    "lever not attached to anything" is a good description. Could also indicate worn mc parts, but more often than not, a bleed. What brand?
    Grimeca System 11 so if the seal is out, I am really SOL. Luckily, bleeding resolved the issue.
    Expert Noob
    I have J3s and the bleed kit is on its way to my door.
