Results 1 to 8 of 8
    Reputation: DavidGrinnell's Avatar
    What do I need ? Older IS tab fork
    Hey guys I finally upgraded my front wheel on my bike and I need to figure out what brake adapter I need to use ... I got a centerlock wheel so I will use shimano for the brakes ... I have nothing yet just the wheel and rockshox sid fork with tabs not post mount...
    Any help would be awesome guys !
    Sent from my Nexus 10 using Tapatalk 2
    Re: What do I need ? Older IS tab fork
    Thanks man
    Sent from my Nexus 4 using Tapatalk 2
    What if i have the opposite problem? It's not the same is it?
    I've upgraded my fork which has postmount setup, but still have the old IS shimano XT's calipers.
    PM fork + IS brake = same or SOL?
    B A N N E D
    Quote Originally Posted by normonster View Post
    There is adapters to fit IS brakes onto PM forks, they are different to the adapters I linked above, they don't work with all IS brakes and they don't work on all PM forks .
    What model brake do you have and what size front brake caliper do you have ?
    I've got XT hydraulic from around 2002/2003.
    Should be for the smaller rotor, maybe 160. do you know if this might work?
    B A N N E D
    If you have a 160mm BR-M755 then you can get an adapter but you'll probably have to use a 180mm adapter and upsize to a 180mm rotor.
    The design of that model caliper means that it probably won't work with a 160mm adapter
    160mm caliper + 160mm adapter + 6" post mounts = 160mm rotor
    180mm caliper + 160mm adapter + 6" post mounts = 180mm rotor
    160mm caliper + 180mm adapter + 6" post mounts = 180mm rotor
    180mm caliper + 180mm adapter + 6" post mounts = 200mm rotor
    180mm adapter: http://www.niagaracycle.com/categories/shimano-sm-maf180-front-post-mount-adapter-180mm-post-i-s
    160, 180 & 200mm adapters: http://clee-cycles.co.uk/esite/P1043/product
    Read these threads.
    http://forums.mtbr.com/brake-time/magura-marta-2006-front-adapter-775269.html
    http://forums.mtbr.com/brake-time/magura-marta-sl-adapter-help-832740.html
    http://forums.mtbr.com/brake-time/what-shimano-brake-adapter-s-would-i-use-816157.html
    Good info Cobba!!!
    Thanks much!
  1. looking to buy a Fox Van 160 or older Totem coil fork
    By 47car in forum Shocks and Suspension
    Last Post: 10-12-2012, 04:36 PM
  2. Need some fork help for a older newbie...
    By TJay74 in forum 29er Components
    Last Post: 10-06-2012, 06:24 PM
  3. What new fork for older Trek MTB?
    By swimman in forum Shocks and Suspension
    Last Post: 08-21-2011, 11:09 AM
  4. Older Z-1 fork on TransAM
    By jbf in forum Transition Bikes
    Last Post: 06-30-2011, 09:33 AM
  5. help new FORK for older bike
    By tefloncat in forum Shocks and Suspension
    Last Post: 01-31-2011, 12:31 PM
