Results 1 to 3 of 3
    what are disc options on a frame w/ hayes mounts?
    my 2001 homegrown frame has "hayes mounts". at least that's what i've been told. the holes drilled for the rear disc caliper are about an inch apart and are on the chainstay. do these sound like "hayes mounts" and if so what are my options for disc brakes?
    thanks,
    head mcm#500
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    Quote Originally Posted by head
    thanks,
    head mcm#500
    Those are 22mm mounts aka parallel mounts.,
    http://www.discbrakeadapters.com/
    they have parallel mount converters to IS $23 , as well as some other nice pieces that you can use.
    Reputation: Eggman's Avatar
    depends on your frame
    thanks,
    head mcm#500
    the previous post was correct, there are adapters, but not for all frames. my 2001 klein for example can take ONLY the 22mm hayes hydros, the space where the mount is was too tight for an adapter.
    best bet is to call schwinn (do they still exist under that name?) and ask them for a recommendation.
  1. Buying the Dean frame...what are my options now?
    By iamnate in forum 29er Bikes
    Last Post: 02-24-2004, 08:39 AM
  2. Do pre 2000 model Marzocchi's come with IS disc mounts?
    By Ganze in forum Shocks and Suspension
    Last Post: 02-19-2004, 11:26 AM
  3. Adding disc mount to horiz. dropout frame?
    By Singletrack Pig in forum Singlespeed
    Last Post: 02-03-2004, 04:17 PM
  4. Getto fab project: disc on a non-disc frame
    By zedro in forum Downhill - Freeride
    Last Post: 01-27-2004, 11:39 AM
  5. Running Hayes Disc in the wrong direction??
    By Bikebrain in forum Brake Time
    Last Post: 01-15-2004, 10:06 PM
