Results 1 to 5 of 5
    May 2013
    New question here. what Avid IS adapter to I need for my Trek Fuel?
    I've got a 2002 Trek Fuel 100 carbon frame that I am refreshing/upgrading. I bought a pair of Avid BB7 brakes to install. But I don't know what IS adapter to get/use. The included adapters are too long (bolt holes spacing)
    The rear dropout of the Trek has a set of "IS" holes to mount a disc brake that are about 44mm apart. I.e., closer together than the 51mm standard that the included adapters are.
    Does Avid make a "44mm" IS adapter? And, if so, what stand-off height would I need to get the caliper positioned properly for the 160mm rotors? Is there a way to calculate this?
    Thanks for any help for a Disc Brake newbie
    Reputation: Ronnie's Avatar
    You have the BB7 brakes so you have the fitting instructions which have all (three) available rear adapters listed. As far as I know and remember all the bikes I've had going back to the early 2000s had a 51mm. IS mount. I own a great German made "Steppenwolf" bike on which I'd like to fit a rear disc brake. (Got a BB7 on the front.) It also has two threaded holes on the seat stays near the dropout which are about 4cm. apart. I always assumed they were for mounting a fender or carrier as there are the same holes on both sides. I doubt that you can mount a caliper there but if you find anything let me know.
    There is the Brake Therapy option but at the price I'll stick with the V-brake on the back.
    The trouble with having an open mind is that people will insist on trying to put things in it.
    B A N N E D
    You will need this bolt on mount and then you'll need a IS to PM adapter of the appropriate size to suit the rotor that you'll be using. Trek started using this bolt on mount a couple of years ago on their 3 Series bikes, your local Trek dealer should be able to order you one of these mounts.
    You can buy this bolt on mount on ebay but they are a bit more expensive.
    www.ebay.com./itm/Rear-Disc-Brake-Adapter-for-Gary-Fisher-Trek-Klein-Frames-Universal-Mount-Disk-/350739744602?
    With the following bolt on mount you wouldn't need a IS to PM adapter when using a 160m rotor.
    www.ebay.com/itm/Rear-Disc-Brake-Adapter-for-Gary-Fisher-Trek-Klein-Frames-160mm-Post-Mount-Disk-/350739673837?
    You can see photos of the Trek bolt on mount attached to a 2002 Fuel frame on the following link.
    http://singletrackworld.com/forum/topic/trek-fuel-80-2002-175-frame-bits-1
    May 2013
    Quote Originally Posted by cobba View Post
    I ended up buying the second one you suggested: the 160mm integrated adapter, from "Sellution Components" on eBay. Hope to receive it soon (the seller only lives 10 miles from me, but 3 days in-transit so far? Love USPS!)
    Hopeful that this will result in a clean mount that doesn't flex too much. I'll post my results.
    Thanks Cobba, for taking the time to post such a thorough response!
    Reputation: 02_NRS's Avatar
    frame adapter mounts/
    44mm adapter mounts-trek warehouse has them $15./ order thru any trek dealer.
  1. Replies: 17
    Last Post: 11-09-2013, 06:58 AM
  2. Replacing Avid Elixir R brakes with XTR on Trek Fuel EX
    By ChuckChurch in forum Brake Time
    Last Post: 05-06-2013, 07:09 AM
  3. Trek Fuel Ex 8 vs. Fuji reveal 2.0 vs. Trek Fuel Ex 6
    By WilliamM10 in forum Beginner's Corner
    Last Post: 01-15-2012, 06:19 AM
  4. 2011 Trek Fuel EX5 or 2008 Trek Fuel EX9
    By tavorh1 in forum Trek
    Last Post: 11-08-2011, 07:07 PM
  5. 2010 Trek Top Fuel 8 vs 2011 Trek Fuel EX 8
    By David S - Sydney in forum Trek
    Last Post: 01-12-2011, 07:08 PM
