Results 1 to 2 of 2
    Washers setup on a disc brake with a 180 rotor adapter ?
    I'm asking this question because I have just setup a 180 mm rotor with Shimano M596 calipers using a Shimano adapter. My LBS set it up like this: post mounts - adapter - washers - caliper. He said it should be so to allow adjustability of the caliper.
    What is happening is that the pads are not sweeping about 20% of the lower part of the rotor. i.e The caliper is a bit higher.
    I looked at Shimano techdocs and they show it like this: post mount - adapter - caliper - washers. If it were done like this it would lower the caliper and probably the pads would sweep the whole rotor area. Is this correct ? If it were to be done like this there would be no adjustability of the caliper.
    How is your setup ?
    The adapter is the right way up.
    Reputation: Pedro S's Avatar
    Oct 2010
    Your LBS did it wrong. Set it up as illustrated in the techdoc. Look
  1. Replies: 3
    Last Post: 12-29-2011, 07:14 AM
  2. F29 brake adapter for 180 rotor
    By OilcanRacer in forum 29er Bikes
    Last Post: 04-22-2009, 03:58 AM
  3. disc rotor bolts and washers?
    By da_eddio in forum Brake Time
    Last Post: 04-18-2008, 08:26 AM
  4. Replies: 4
    Last Post: 02-29-2008, 06:02 PM
  5. What disc brake rotor adapter?
    By VolcanicOne in forum Kona
    Last Post: 05-04-2007, 10:27 AM
