Thread: warp rotors
    Lumen warrior
    Reputation: XC707's Avatar
    Apr 2005
    warp rotors
    i had an avid bb7setup with 203mm rotors and it seems that my rear rotors have a slight rubbing problem, when i checked it ,it appears that the rotor is warped , is there any remedy for a slightly warped rotor or do i have to replace it? its a new setup and i dont wanna spend for another rotor.
    There's no app for this.
    Reputation: JimC.'s Avatar
    disc brake
    FAQ... over in the upper right. Jim
    Bad Case of the Mondays
    Reputation: Jdub's Avatar
    Quote Originally Posted by XC707
    You can true them, as mentioned check the FAQ. However, one of my Avid rotors (the round one I got with a BB7) will not stay true, regardless of how many times I true it. Same spot every time, so YMMV.
    Lumen warrior
    Apr 2005
    thanks for the info , ill try to true my rotors later, by the way, can u recommend a rotor brand that stays true longer than the original avid?
  1. Splined rotors... Shimano vs. Avid... Compatability?
    By MidshipmanX in forum Brake Time
    Last Post: 02-03-2005, 10:54 AM
  2. a2z rotors?
    By FoShizzle in forum Brake Time
    Last Post: 12-09-2004, 06:37 AM
  3. Up-sizing Shimano XT rotors to 180 or 200 mm
    By Dave99 in forum Brake Time
    Last Post: 09-22-2004, 11:36 AM
  4. Replies: 1
    Last Post: 08-17-2004, 05:54 PM
  5. Reason for warped rotors... not what you would expect..
    By BudhaGoodha in forum Downhill - Freeride
    Last Post: 08-13-2004, 01:12 PM
