Results 1 to 11 of 11
    himom!
    Valvoline Dot 3/4 Hydraulic Fluid - acceptable?
    So I need some more fluid for my Avid Elixir brake system. This - http://www.valvoline.com/pages/produ...sp?product=138 - is this the best fluid available at my local auto parts store. Is this good enough for my brakes or should I look around more for some Motul branded fluid (which generally seems to be recommended on my MTBR searches)?
    Yep, that's fine. I recommend it and the search will produce those results as well. I don't know how it differs from the other Valvoline synth we see at autozones, however.
    I would just go to the parts store and pick that up. It's easy and it's cheap.
    himom!
    Thanks Jerk. I already picked it up. I didn't do any research before walking into the auto store. I just bought the most expensive Dot 4 fluid I saw (being in the USA, no 5.1 available, of course). Worst case scenario, the fluid reduces my braking performance and I've wasted $3.61, right?
    Many DOT 4 fluids have better temp handling than DOT 5.1. It's not always about the number. The valvoline will likely exceed or match the characteristics of the 5.1
    The Beast Breathes
    Reputation: mountain_bomber156's Avatar
    Ummm...
    I thought that's why they made mountain-bike brake specific brake fluid.
    http://www.universalcycles.com/shopp...hp?category=16
    Good luck with that, mister 300-Mile Turn Radius.
    Oct 2007
    you're not going to notice a difference between motul, and the stores generic, cheapest dot3 brake fluid.
    valvoline syn is a very high quality, very high boiling point DOT4 fluid, with quality far beyond what you need for a bike. its a good choice.. cheap and reliable, readily available.
    Quote Originally Posted by mountain_bomber156
    I actually snorted some mineral water into my nose when I laughed reading that post.
    The Beast Breathes
    Quote Originally Posted by Jerk_Chicken
    why?
    Oct 2007
    because theres no such thing as bike specific brake fluid. its normal brake fluid poured into a little bottle and marked up 10x.
    The Beast Breathes
    Quote Originally Posted by tomsmoto
    Ok.
    Reputation: vk45de's Avatar
    Am I missing something? All it says is you can't put the wrong fluid into your brakes (which is correct), nothing about bike vs car brake fluids.
