    Reputation: xisaacx's Avatar
    v brakes vs mechanical disc
    hi everybody
    what do you recommend for cross country use v brakes or mechanical disc brakes.
    ill love a hidrahulical disc brakes but ai cant afford them by now. so i have to decide between mech or vs.
    i hope you can helop me to decide.
    Formerly RyanC
    Quote Originally Posted by xisaacx
    hi everybody
    Most people here are probably going to recommend discs, me included. For XC riding it depends, sometimes vees work just fine and they'll save weight over a mech disc setup. Consult the FAQ, it has a blurb about this. If you go mech disc, go all the way and get Avid's. Cheap for discs, but a good investment that you won't feel are lacking or in need of an upgrade down the road.
    -Ryan
    xc racer wannabe
    Reputation: jonwebah's Avatar
    personally i'd rather have mech discs over v's any day, but v brakes do work pretty well and reliably in dry conditions. the only disadvantage of discs is the slight weight gain, but i personally feel it is negligable considering the vast benefits. i'd say the thing i was shocked most with was the increase in modulation on steep descents; i wasn't just locking my rear wheel and dragging it around, i was actually able to control the rate at which it was slowed.
    i have the hayes mx-1's on my bike -- and they've worked flawlessly so far, but they came stock on my bike and were set up well. if you're adding new brakes to your bike i'd have to say go with the avids. it seems like a lot more people are satisfied with how they work and it also seems like people have better luck setting them up on their own than with the hayes.
    don't be afraid of the hayes though, if you're getting them on a new bike. they're really quite excellent and the negative reviews on mtbr i believe to be accounted for by improper setup.
    thanx
    thanx.
  1. Surly 1x1 and Avid mechanical disc brake issues...
    By pennstatebiker in forum Singlespeed
    Last Post: 05-16-2004, 04:54 PM
  2. Need advice on using disc brakes
    By moose in forum Brake Time
    Last Post: 04-05-2004, 11:18 AM
  3. Ahoy! V-brake holdouts!
    By Padre in forum Singlespeed
    Last Post: 03-23-2004, 10:06 AM
  4. Avid Mechanical Disc Brakes
    By FUEL in forum Brake Time
    Last Post: 03-11-2004, 11:12 PM
  5. regular brakes and disc brakes
    By joshua_msu in forum Brake Time
    Last Post: 03-05-2004, 09:07 PM
