Results 1 to 5 of 5
    V-Brakes Questions - Pulsation in rear brake
    I'm pretty sure I need new Pads for both brakes, thinking about some salmon Kool-stops,
    was just riding today, and felt the back brake pulsating as I was coasting into the parking lot (fairly low speed). I'm sure whatever's happening is going on at higher speeds, but i just don't pay so much attention will bashing down the trail as i do in the lot maybe.
    - I'm hoping this is just the pads in their final death throws, but wanted to see if you guys thought it might be something more serious.
    (its a 2003 Fisher Tassajara with stock Promax V-brakes)
    Andy
    Gravity - it's not just a good idea, It's the Law!
    Take a look at the rim very carefully. It could be worn, but the weld is still high.
    Fat-tired Roadie
    Nov 2007
    It might be contaminated. Try cleaning the rim with rubbing alcohol. If you're tossing the pads anyway, doing both at the same time is good. Otherwise, take a look at the pad surfaces - if they look as glazed and skanky as V-brake pads on bikes that get ridden tend to, sand them down a little.
    It can also be a hop in the wheel. Does it spin true? SSVT gives another good possibility.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    "Pulsating" makes me think that it could be something with the rim, too. Rim not straight or something in the surface.
    Better give the rim a good cleaning before you start using the new pads.
    Koolstops are the best rim brake pads that I ever used. Cannot remember which model I had...
    Thanx for the help guys! I spent the morning cleaning and investigating, and i'm pretty sure its not the rim wear (although it IS an 8 yr. old rim, probly 2000 miles on it or more) but more likely a combination of contamination (taken care of) and a wobble/hop in the wheel. i played a bit with the spokes, and taught myself that i dont know JACK about truing wheels, so maybe its off to the LSB....
    thanx again for the helpful suggestions!!
    Andy
