Results 1 to 7 of 7
    dedicated beater
    V-Brakes don't snap back after I release the brake handle
    So, my V-Brakes don't snap back after I release the brake handle. Just just kinda slowly spread back apart. Is this normal or is something perhaps too tight or something?
    Old man on a bike
    Not enough information. Are the calipers clean and well lubed? Is your housing/cable in good condition? Do your levers have a return spring?
    suum quique
    Mountain Man Dan
    Reputation: ProjectDan35's Avatar
    Lubricate the posts the brake system mounts onto the fork, also lube the spring. Happened to one of my bikes, I used regular grease. then put back on. i also tightened it too much causing it not to snap back, so back it off a bit.
    The bike is nothing more then circles turning circles, It's the human motor that makes it elegant.
    IdontShootPeopleAnyMore
    Reputation: DriveByBikeShooting's Avatar
    99% of the time in my experience it is crud in the cables... the other precent of the time it is bad springs or something going wrong in the pivots...
    What mountain bike forum do pirates use? .....
    MTB-arrrrrrrrrrrrrrr
    Jun 2010
    I just had this happen to a neighbor on his brakes. Make sure the pads are hitting the rim and when you release make sure they are not so close to rubber that they are getting hung up. My neighbor crashed and moved the pads which caused his issue. We just loosened the pads, moved to proper place and retightened. Problem fixed.
    I am going to second DriveBy. I am still running V-Brakes on one of my bikes and 99% of the time when the levers don't return it is due to the cable/housing. There is either crud in the housing which happens a lot when it gets wet or there is a kink in the cable and or housing which also just happens a lot. Check your cable and housing! Good Luck.
    dedicated beater
    Hey, thanks a bunch guys. I'll look at it a bit more.
