    V brake cable & housing question
    I just replaced a set of cable/ housing and found out the old cable still appeared to be in pretty good shape, it's the housing that got all the dirt and beaten up. Since I have lots of housing left, should I just replace the housing next time and leave the cable alone?
    B.T.W. how often do you replace brake and shift cable for your bike? I used a Shimano M-system (XT) cable but didn't improve that much, would a XTR or teflon coated cable make a difference? Thanks
    Cheezy Rider
    Reputation: Rufudufus's Avatar
    Cable's cheap, visiting the hospital after your brakes fail isn't. Spend a couple bucks on a new one. Conventional wisdom is to replace them yearly. I don't follow that religiously, but if you're taking the time to replace the housing throw a new cable in there. I've heard some teflon-coated cables tend to lose the teflon over time, I'd just go with stainless.
    Reputation: shiggy's Avatar
    Dec 1998
    I much prefer Teflon coated cables. I use full length housing and no lube. Works great.
    mtbtires.com
    Cheezy Rider
    Quote Originally Posted by shiggy
    I'll defer to Shiggy. I was reading old reviews of Avid Flakjackets the other day, and they mentioned the Teflon coating deteriorating. May have just been Avid's implementation. I will say my new, Teflon-free Flakjackets are very smooth, we'll see how they hold up.
  1. Brake cable question on singlespeed conversion
    By dirt_donkey in forum Brake Time
    Last Post: 02-04-2005, 07:55 AM
  2. Shimano road brake cable recall.
    By Axe in forum General Discussion
    Last Post: 01-25-2005, 01:40 PM
  3. Shimano road brake cable recall.
    By Axe in forum Brake Time
    Last Post: 01-25-2005, 12:55 PM
  4. what cables for v-brakes?
    By dansjustchillin in forum Brake Time
    Last Post: 01-15-2005, 10:51 PM
  5. Avid mechs - housing question / problem...
    By DSR in forum Brake Time
    Last Post: 03-03-2004, 12:29 AM
