Results 1 to 2 of 2
    a cycologist
    Reputation: DBomb's Avatar
    V-brake adjustment rod?
    Is the rod that runs along the back of the v-brake arm used to adjust it? Does anyone know what I'm talking about? Instead of turning the screw to fix the reach(?) you can ratchet the rod. If this is possible, how does it work? I think I saw someone do this once when he was riding and there was a lot of mud on the rim and he needed more space between the pad and the rim.
    "Spread love. It's the Brooklyn way."
    Biggie Smalls
    Two wheels are best
    Reputation: DM-SC's Avatar
    Did he remove the arm from the boss?
    You can adjust return spring tension on v-brakes by removing the arms and then installing them with the locator pin in one of the 3 pin holes (usually).
    When I've run v-brakes, I used the middle hole mostly. I did have to use the highest tension setting on the rear of a Schwinn S-20.
    Never be afraid to try something new.
    Remember amateurs built the Ark.
    Professionals built the Titanic.
  1. Replies: 13
    Last Post: 01-30-2010, 11:53 PM
  2. Which brake lever for which brake...?
    By mahgnillig in forum Brake Time
    Last Post: 10-06-2004, 02:18 PM
  3. Rear V brake adjustment with ENO hub?
    By jh_on_the_cape in forum Singlespeed
    Last Post: 06-08-2004, 01:24 PM
  4. When bending metal was brake adjustment.
    By Wm. L. in forum Vintage, Retro, Classic
    Last Post: 03-20-2004, 07:36 AM
  5. Brake pad adjustment gauges
    By SS Jerry in forum Brake Time
    Last Post: 03-12-2004, 12:30 AM
